need some advice taking off this body kit
The sides are from wings west, and here is all the info ive gathered by observation. its somehow just glued onto the car. on the back/underside of the kit, i see a black silicone type deal. im not too worried about that, ive researched that stuff and it comes off, with patience, but it comes off. the part that worries me is this.
as you can see from the pictures, they used something to fill the seam, maybe the same black silicone, and then painted over it.
my plan of attack, is to use a razor blade and cut the seam from the painted side, and then depending on how deep into the glue i can cut, maybe snap off the piece towards the bottom?
any helpful advice would be great
The razor blade sounds okay as long as you don't hit the body of the car at all.
I would try to cut and pry it at the same time.
Most likely when you are done you will need to paint match the bottom of your car, unless that crap comes off fairly easily.
Good luck. . . . !
