Need Advice for Detailing Supplies
Old Nov 11, 2008 | 11:10 PM
98 WS6's Avatar
Default Need Advice for Detailing Supplies
Alrighty,
So my car is red, and from what I understand that is the hardest color to deal with. I have some (what I think?) is oxidation on my hood. It's lighter than the red paint everywhere else, and on the outsides of the hood there are these weird whitish streaks. In the sunlight, you can actually look at the car and tell that the hood is different. The front bumper is also losing it's shine and has some damage. I have some swirls in the paint too.. So I need your help!
This is what I have so far.
Porter Cable 7424 Kit from Tropi-Care (have to support such a cool guy )
http://www.tropi-care.com/Porter_Cab..._p/tcpc-10.htm
Kit comes with:
Buffer
3 pads: Orange (cutting/polishing) white (light cutting) and blue (final finishing)
Lake Country backing plate
Two "reversible blue microfiber polishing bonnets for residue removal"
I also figured that Menzerna Intensive Polish is also what I would need here, right?
That's about where I stand, is there anything else I should have, or that I need?
Old Nov 12, 2008 | 12:37 AM
slayerized6's Avatar
clay bar, meguiars colorX, and a hand wax. ive seen your car in person and it doesnt look like it needs major work. if you want to use a rotary, practice on a scrap fender/hood from a junkyard; dont want to burn the paint
Old Nov 12, 2008 | 01:36 AM
Ehatcher's Avatar
definitely get the PC 7424. The oxidation you are referring will not come out by hand very easily. Plus the PC's are extremely simple to use and almost impossible to damage paint with.
Old Nov 12, 2008 | 01:41 AM
Mr. Luos's Avatar
Portercable for sure.
Be ready to spend a LOT of time working with the Menzerna. It is worth it, but the process done properly will take a lot of time. Hood alone may take an hour. Really need to work it in and let the product, pad, and heat do its thing.
Menzerna is top of the line though, and should product GREAT results.
Old Nov 12, 2008 | 02:26 AM
ssbowtie1's Avatar
I'm looking for the same information. After using the intensive polish do you go right to a wax? Do you apply the wax with the PC too?
Old Nov 12, 2008 | 02:49 AM
98 WS6's Avatar
Sounds good. So definitely get the Menzerna Intensive polish? Or is there something else?
I have no problem with it, but why does it take so long? Am I gonna have to put the polish on the hood, and work it in for a long time? Or am I gonna have to work it in, buff it off, work more in, and over and over. or is it moreso just working it in for a long time?
I can't wait to get this stuff, i'm asking for it for xmas lol.
Old Nov 12, 2008 | 10:03 AM
Steve P's Avatar
LS1TECH Sponsor
The PC/Menzerna IP combo is an excellent starting point for restoring the paint surface on many vehicles. It's safe and will yield great results for the beginner or novice without damaging the clear coat. I suggest learning the product/machine capability on a very small section until you're satisfied before proceeding with the rest of the car.
Scratch resistant clear coats while being harder to scratch take longer to remove scratches and other blemishes. For these surfaces, I suggest the Menzerna SIP.
Once you're satisfied with the correction results, you can remove the residue using a solution of isopropyl alcohol and water. Be prepared as Menzerna does leave a fair amount of dusting while working. If there is no micro-marring, you can proceed with your wax or sealant application stage. On darker colors, any resulting haze from buffing can be removed with a finer polish such as Swirl Cutter and a white polishing foam pad.
I like to use our Sealant xP for lighter colors or either one of our new Carnauba Cremes for darker colors to give that additional depth and glow.
Be sure to use the "10offTC" discount code for all orders over $50 to get 10% off your order.
Contact me with any questions at steve@tropi-care.com
Old Nov 12, 2008 | 12:38 PM
Brian2006's Avatar
Red isn't the toughest color. Black is.
If it were me, I would get a yellow pad and Menzerna SIP if you have oxidation on the hood
Old Nov 12, 2008 | 03:34 PM
98 WS6's Avatar
So should I get super intensive polish then, instead?
Old Nov 12, 2008 | 03:42 PM
Brian2006's Avatar
I would. I'd also get the more abrasive pad (yellow)
