Another Bitten Camaro
Nifty....why is that thing pointing off to the side or is it the angle of the shot
And I stand corrected..Niffity is the first Huger Orange....
I am the first Hugger Orange
, had it over a year! And BitViper, the "lean" is the antennae; that is why I had asked if you might make an angled base. It has always had a "G'd up" stance Is is it stock GM base?
Here's the numbers for the stock set up from GM
Fixed mast--10425536 -- stock antenna
Bezel-------10298264 / 10253391 --this is what you need
Bracket-----10282649
Attach bolt-11515756 - not needed
If it is you might be able to rotate it so that it sits right
and shoot me a line if theres anything I can do to help ya out!
