trans am projector headlights? 98-02
Copy & Paste Moderator
Rally Lights. Same place I bought mine. DirtyBird222 bought the H7 90mm and I bought the H9 90mm. If you want a true HID setup, the D2S version is now available as the projector only instead of in an overpriced kit, but the D2S projector costs more than the H7 and H9 versions. Also, I haven't seen the output of the D2S version, but it should be better since its a real HID projector instead of a halogen projector retrofitted to HID.
Originally Posted by The Alchemist
Dirty Bird, I know you said you already had the bumper off, but was it neccessary?
Who knows, maybe I'll pick up a set and look into this.
https://ls1tech.com/forums/appearanc...hting-faq.html
my bad, its black bird lighting solutions. they make kits
Hey NEW GUY, you do realize you just answered a nearly 7 YEAR old thread right? also you don't need to make a second post to correct something, use the EDIT button and fix your first post.
