How to: The camaro light panel
Old Dec 11, 2008 | 01:01 AM
  #41
AxisOfOil's Avatar
kind of like yours...
but with less light bleed... and the potential for changing colors/intensities between each letter. like a little light show! lol.
anything is worth the whole lot of extra effort even for a little gain if it's what you want to see your car do though.
Old Dec 11, 2008 | 02:29 AM
  #42
DRSITES's Avatar
As a side note, I'd strongly reccomend wearing a filter mask, the tail panel is made from fiberglass composite, and as stated, you create a lot of dust...
Old Dec 11, 2008 | 08:51 AM
  #43
jvillescamaroz28's Avatar
i would like to see your progress and finished product....as stated before im always intrested in an upgrade
good luck
Old Dec 11, 2008 | 09:24 AM
  #44
AxisOfOil's Avatar
I'll do a write-up for sure on the "Axis corollary to the Camaro light panel".
that is... when I get around to it.
I'm looking for a good controller for 18 LED's... any ideas? lol.
(and yes... I do mean that I want one of each primary color in each letter. and yes... it will be a pita)
Old Dec 14, 2008 | 10:28 PM
  #45
ryonyanko's Avatar
can you use VHT on the camaro part to make it black instead of white for non berger.
thread revival
Old Dec 15, 2008 | 05:58 PM
  #46
yes you can.
but a strip of tint will work as well. it will be shiny but it will look good and serve the same purpose.
Old Dec 15, 2008 | 06:17 PM
  #47
AxisOfOil's Avatar
thread revival
you could... or you could tint it, like stated above.
If you don't want it shiny, they make different colors of diffusing plastic (might have to look them up... sometimes they're hard to come by... stage lighting supply shops usually have them.)
Old Dec 15, 2008 | 07:13 PM
  #48
FastRidesOnly's Avatar
i'm gonna do this real soon.
where do u buy the led lights at and how much money?
Old Dec 15, 2008 | 08:15 PM
  #49
i got a light bar from optx by street glow... some actually build a led board... and some find other means of lights
i bought a rear panel, didnt want to screw mine up
light
and had a body shop paint it
only had 150 in the whole project
Old Dec 15, 2008 | 08:30 PM
  #50
'02SOMz28's Avatar
yea i got to do this!!! great job man!!!!!!!!!
Old Dec 16, 2008 | 12:40 AM
  #51
thats_10kid's Avatar
well i could NOT find that light bar ANYWHERE....so i bought it strait from street but with a very heavy price....58$ shipped to my door....and i am waiting to get me car back from the shop so i can finish mine...will post pics as soon as im done..
Old Dec 16, 2008 | 11:07 AM
  #52
L3THAL_Z28's Avatar
i really like this...i have one question tho....can it be wired so that its lit up when your lights are on but when you hit the brakes it lights up brighter? would i need the LED bar w/ this or can it be done with the neon light bar?
Old Dec 16, 2008 | 11:22 AM
  #53
AxisOfOil's Avatar
neon tubes don't do incremental lighting iirc.
to do it stepped, yes, you can. there are a couple ways.
the easiest would be to have two sets of lights, one wired to your drl's or side markers, etc... one of the sets of lights that come one when you're looking to have it come on.
and then wire the second set to your brake lights.
neon tubes take time for the ballast to kick in i think, so wouldn't be ideal for wiring to the brake lights.
Another way... I think you can wire led's and normal filament bulbs to run sequential with your drl's, and then have additional voltage pumped to them when the brake pedal is pressed by wiring into the brake lights as well.
I would recommend two sets of lights. Personally, I would use LED's simply because of how long they last, how much cooler they run than neon tubes, how much harder they are to break, etc...
to each his own, and i'm sure there IS a way to do it with neon tubes... i just personally don't like them, so i don't look into them very often.
Old Dec 16, 2008 | 11:40 AM
  #54
L3THAL_Z28's Avatar
cool...thanks axis
Old Dec 16, 2008 | 12:17 PM
  #55
AxisOfOil's Avatar
yeah. i might not be able to help out too much with breaking drivetrain stuff... or know much about building engines...
but, I am an A.D.D. master... flashing and blinking lights are fun!!!
lol... oh, and I have i think a 12" or 20" green light bar (neon equivalent, not technically neon ) + ballast set up to run on a 12v dc current. it was originally meant to be a trunk light for the mustang when i got it.
idk how long you're planning on waiting to do this... but give me until the next semester starts and settles off and i'll see if it will come on right away or if it has a ballast lag like the ones we tried to use for stage lighting did. (they worked great for lightNing though, lol)
Old Dec 16, 2008 | 02:31 PM
  #56
dave70's Avatar
On the first page a mod removed the name of the place you got the tail lights for non sponsor pimping. Is there a sponsor who sells them? And if not why was it removed? Thanks guys.
Old Dec 16, 2008 | 04:07 PM
  #57
L3THAL_Z28's Avatar
lol sounds good...I be doing this within the next couple of months so if u would find out that would be cool
Old Dec 16, 2008 | 11:10 PM
  #58
AxisOfOil's Avatar
Like I said... as soon as I get settled back in after winter break.
The stuff is all in my dorm. :'(
Which i'm locked out of till the 7th.
Old Dec 17, 2008 | 12:15 AM
  #59
FamousZ's Avatar
I love the look of this..
Old Dec 17, 2008 | 01:53 AM
  #60
01ssreda4's Avatar
good question
