Dynamat
Old Feb 18, 2002 | 10:18 AM
Currdog's Avatar
Default Dynamat
What's the verdict on this stuff? Is it worth it? I want to cut down on some of the road noise, so I'm thinking about covering the rear (like they did in install on the project trans am site.)
http://www.projecttransam.com/projects10.htm
Anyone with first hand experience?
Thanks
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 18, 2002 | 11:40 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Dynamat
It works great for killing road noise, but the stuff is somewhat heavy and will add weight to the car. I used to install that stuff when I was into car stereos.
I've found that certain tires cause more road noise than others....
Tony
Old Feb 18, 2002 | 11:49 AM
CHRISPY's Avatar
Default Re: Dynamat
If you could throw in an easily removable piece you could take it out at the track <img src="gr_stretch.gif" border="0">
Cheers,
Chris
Old Feb 18, 2002 | 07:23 PM
Nocturnal-TA's Avatar
Default Re: Dynamat
go to www.b-quiet.com I used their brown bread product very nice. much much cheaper than dynamat extreme as just as good. I used about 70sq feet. Road noise is a lot less, and my LM does not resonate anymore!!! Stereo hits louder too, well worth the small weight gain of less than 20lbs.
what is a loss of 1/8 of a tenth when you can improve your ride quality that much? If you need that, just take out some other heavy object, spare, backseet, etc.
[ February 18, 2002: Message edited by: Cybertech ]</p>
Old Feb 18, 2002 | 11:10 PM
Bobby C 01TA's Avatar
Default Re: Dynamat
will this also help reduce that flutter noise caused from headers/ory if i dumped some dynamat in the back hatch?>
Old Feb 20, 2002 | 12:24 AM
SSG-Z28's Avatar
Default Re: Dynamat
I just sprayed rubberized undercoating everywhere!! <img src="gr_images/icons/wink.gif" border="0">
Old Feb 21, 2002 | 10:25 AM
Default Re: Dynamat
[quote]Originally posted by JackZ28:
<strong>I just sprayed rubberized undercoating everywhere!! <img src="gr_images/icons/wink.gif" border="0"> </strong><hr></blockquote>
whoa.. what the hell?? they have that??! how much for a can or bottle and where can i get it? How good does it insulate.. any links to it on here? thanks!
