Has anyone put a 335 section width tire on the back of a Camaro?
Old Feb 20, 2002 | 11:48 PM
H8 B N SLO's Avatar
Default Has anyone put a 335 section width tire on the back of a Camaro?
How much modification to the car does it take? Rolled fender lip, beat the crap out of the inner fenders, etc.?
Old Feb 21, 2002 | 12:02 AM
DriveATransAm's Avatar
Default Re: Has anyone put a 335 section width tire on the back of a Camaro?
on what rim?
i got 17x11 TTIIs and 315s on them. rubs a little on the bumper block thing, but when you lower the car its ok. looks like theres a little more room, but the fit is TIGHT. ill check it out tomorrow and double check the clearance.
Old Feb 21, 2002 | 01:23 AM
H8 B N SLO's Avatar
I will be running HREs. I thought that I could get all the wheel dimensions from someone that has actually done it. Since HRE custom builds all their wheels it wont be a problem to have them made with a specific ofset or back spacing.
I am actually wanting to run a 335/25YR19 on the back. I'm guessing it would be a 19x12 wheel?
The car will be lowered with Eibach springs.
Old Feb 21, 2002 | 09:06 AM
bigSS's Avatar
I have seen 325s I the rear before... GM fit some 335s on there too for there ZL1 car. They made it fit without to much mods, I think they just rolled and trimmed the fender lip...
Old Feb 22, 2002 | 02:13 AM
H8 B N SLO's Avatar
Anyone know for sure?offsets/back spacing? I dont want to spend thousands of dollars for wheels and tires that won't fit
Old Feb 22, 2002 | 08:19 AM
Big Mike's Avatar
For a 17x11 you will need a 7.5" backspacing.
Old Feb 23, 2002 | 03:22 AM
Dope's Avatar
[quote]Originally posted by bigSS:
<strong>I have seen 325s I the rear before... GM fit some 335s on there too for there ZL1 car. They made it fit without to much mods, I think they just rolled and trimmed the fender lip...</strong><hr></blockquote>
The ZL1 actually has flared rear fenders.
I don't think it's very possible to fit 335s in the back without modification. Most people with 315s have to bang the wheelwell or roll the fender lip (or both). 335s are almost a full inch wider. You'd have to have that full inch of width towards the inside of the car, which means you'll need another inch of wheelwell clearance all around. That's a LOT of beating <img src="gr_stretch.gif" border="0"> plus I don't know what's on the otherside of the wheelwell all around the circumference of the tire/wheel.
If you chose to have the wheels stick out that extra inch instead, you'd have to flare the fenders.
All of these conditions are hurtin' even worse when you lower the car.
Good luck if you do it, it's gonna take a good bit of work, I think. Also, for the record, I don't think anyone has 19x12s in the back, that I've ever heard of in the past few years, at least.
Heh, I was looking up the tire height of a 335/25/19. Stock height, but christ, the price caught my eye. I could only find one tire in that size (Pirelli Pzero) and they are over $400 A PIECE.
But, I guess, if you can afford HREs, you can afford 400$ tires too <img src="gr_stretch.gif" border="0">
Dope
Old Feb 24, 2002 | 04:07 AM
H8 B N SLO's Avatar
I have got a few emails saying that they can will fit with rolling the fenders and hammering the inner fender wells. One guy said that he has them mounted on a 17x11 and he didn't have to do a thing.
The more answers I get the more confused I get. Keep the replies coming but if worse comes to worse I will talk to someone at HRE about sending me a damaged center with several different inner and outer lips (maybe slightly damaged or new unfinsihed ones) and order one tire and try it.
Old Feb 24, 2002 | 09:41 AM
Jack Daniels's Avatar
I can tell you from experience with 315's that 335's would be 'doable', but to do it right would take a bit of work to have no rubbing.
I have 315's on 11" ZR1 wheels with the GS offset. They tuck in nicely under the fenders but did originally have some rubbing issues in the inner fenders. I was able to take care of that with a sledge hammer and then re-undercoat the areas. I also had to roll the fenderlips some.
I don't like the way the ZR1 offset wheels stick out, however, they would help with the inner fender issues but create more outer fender problems. Plus they do stick out some.
To sum it up in my opinion, the 335's would be more trouble than they're worth. To get 315's to totally not rub in any situation (loads, hard cornering, etc.) is enough work in itself. Unless you keep your car at stock height (mine's lowered), or get an offset that allows the tires to go beyond the fender's outer edge (a look I hate), or just put up with some rubbing (I won't), I'd stay with the 315's.
One more note. I originally had Dunlop 315's and replaced them with Yokohama tires. The Yoko's were a good bit larger and I had to do a little reworking of the fenders again.
Good luck! <img src="gr_stretch.gif" border="0">
Old Feb 25, 2002 | 12:55 AM
alright, had the 315 nittos off yesterday. looked like it was rubbing on the driverside a bit to wear off the coating <img src="gr_eek2.gif" border="0"> . the pas. side had a tad bit of wear, nothing too bad. i just hit the driverside in a little. i did take some really hard turns the night before though. so maybe that had something to do with it <img src="gr_stretch.gif" border="0"> i cant see the 335s fitting unless you get a decent offset.
Old Feb 25, 2002 | 11:49 PM
H8 B N SLO's Avatar
DriveATransAM, you have the GS offset right? Did you roll the fenders at all on your car? How much clearance can be gained by rolling the fenders so the lip actually folds up against the inside of the fender well? Let me check tirerack.com and see what the difference in width is between your Nitto 315s and the Pirelli 335s.
Old Feb 26, 2002 | 12:24 AM
H8 B N SLO's Avatar
Ok,in a 315/35 17 the section width measures 12.6" for the BFG G-Force, Michelin Pilot Sport, Yokohama AVS sport, and Simmitomo HTRZ when mounted on an 11" wheel. The Good Year GSC comes in at 12.4" on an 11" wheel and the BFG Comp T/A drag radial comes in at 12.2" on an 11" wheel.
The Pirelli 335/25 19 section width is 13.2" when mounted on a 12" wheel.
Now, even though the 335 is mounted on a 12" rim compared to the others being an 11" it doesnt matter because we are actually looking at the measurement for the section width, right?
By just looking at the section width of the majority of the 315s it would look like I only need to gain a little over .5" of clearance to get these to fit.
Can that be gained by rolling the fenders and hammering the inner fender wells.
Does this sound right?
Old Feb 26, 2002 | 07:36 AM
i have the f-body offset.
i believe the GS offset will stick out quite a bit more.
Old Feb 10, 2003 | 01:08 PM
Orange Krush's Avatar
The F-body offset and the G rand S port offset are one in the same! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
http://www.afswheels.com/v2/ecommerce/shopexd.asp?id=22
<small>[ February 12, 2003, 08:30 AM: Message edited by: Orange Krush ]</small>
Old Feb 10, 2003 | 02:47 PM
LS69TA's Avatar
I tried 335/30/18 Michelin Pilot Sports on my 18x10.5 Z06 wheels. Just a little too much tire for the rim. The tire shop didn't have enough air to seat the bead. One lip kept rolling up and wouldn't pop out. But, they WILL fit a 10.5" rim. Just got to have a helluva lot of air pressure..the Pass. side will give you problems with clearance b/c of how the wheel well is shaped though. Drivers side should be fine..
<small>[ February 10, 2003, 02:48 PM: Message edited by: C-Note ]</small>
Old Feb 13, 2003 | 12:35 AM
Ireland31's Avatar
Lonnie,
Any progress made on this so far? I was looking at the same thing, 18x12 rear 545's with the 335. Maybe trying to put them on an 18x11.5 would be better. I have 295's on a 10.5" rim right now. I have a lot of clearance on the outside, but slightly rub on the inside with the offset of the wheels I have on the car right now. I havent rolled my fenderlip either. I'll try to find out what the offset of these are. I think they would be about the best off set we could run, and hope it makes it inside the fenderlip on the outside.
By the way, do you still deal with the HRE's? Im going to need to order a set soon.
<small>[ February 12, 2003, 12:37 PM: Message edited by: Ireland31 ]</small>
Old Feb 13, 2003 | 10:09 PM
Black Sunshine/ 00SS's Avatar
I have them on my car. I have the Pilots, 17x335's on TT2 rims, 17x11, with 7.5 BS.
I already had the fender lip rolled, but I had to beat the hell out of the inner fenderwall. I painted over where I hammered, went out, drove it, turned hard to try & make it rub, drive home, and hammered some more. It is a pain, but I dont rub unless I turn hard, or have someone heavy in the pasenger seat. I have Eibach pro springs.
I have some good pics, if someone wants to host them for me. The tires def make a visual statement. I get coments all the time.
Old Feb 13, 2003 | 11:02 PM
JUISSD's Avatar
I ran 325/30-18's on 18x10" TT II's on my 95 Z28. The car was also lowered 1". The ONLY modification I had to do was roll the passenger side fender lip, and that was it. Never rubbed or anything the entire time I had them on the car.
Old Mar 27, 2003 | 04:27 PM
Well FedEx just delivered my 335/35/17 BFG g-Force T/A R1's! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
http://www.tirerack.com/tires/bfg/bf...ing_gforce.htm
Damn things make my 315/35/17 Nitto 555R's look small! <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Well hopefully I get them mounted and balanced tommorrow. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Mar 28, 2003 | 07:46 AM
H8 B N SLO's Avatar
I got my 335/30 18 and 275/35 18 tires the other day. Now just waiting for the wheels to be built, 18x11.5 and 18x9.5 iForged "Aero" wheels.
