show your engine bays
Old Dec 17, 2008 | 08:39 AM
00'blkss's Avatar
Default show your engine bays
was looking for new ideas to make the engine bay cleaner, so was wanting to see how you guys have your engine bays cleaned up.
Old Dec 17, 2008 | 08:47 AM
the_merv's Avatar
Veteran: Air Force
What are you trying to do..get rid of extra stuff?
Here is mine, I removed the non-essential stuff, AC Delete, got rid of some Wiring, and I have a custom Intake for my setup..
And here it is after the Battery Relocation. I don't have full Engine Bay pics of this yet. Also it's a T56 Car now, so the Trans Dip Stick won't be there..
Old Dec 17, 2008 | 08:50 AM
kyles2000z's Avatar
theres tons of these threads if ya do a search...but heres what i have.
when the original owner had the car before i got it....
and now...
since then, ive painted the back of my headlights, consolidated some wires togethers, got rid of my MAF for a SD tune, and also done the whistler headlight mod.
battery relocated to trunk, fuse boxes moved where AIR pump was, covers made from lexan. everything else is pretty much straight forward. all nuts/bolts/washers are stainless, all wiring is relocated that could be, all holes filled and shaved, and everything repainted obviously. also made the coil relocation kit myself, and did all the work in my garage at home including the paint.
Old Dec 17, 2008 | 09:16 AM
firehawk#682's Avatar
^Once again very nice kyle
Here is mine first stock
Here is is now still working on it tho
Wire mod, hood latch cable relocation, egr and air delete, fuse box push down to where the air pump was, evap relocation, custom fuel rail covers and airlid by me. Next will be filling and painting the engine bay.
Old Dec 17, 2008 | 09:30 AM
kyles2000z's Avatar
any better pics of how you have the cover mounted on the driver side? mine just sits on block of wood with velcro
Old Dec 17, 2008 | 09:48 AM
Spd-Kilz's Avatar
The best plan is to always keep it simple - it's better to take away stuff than to add it.
!Wire Mod
!Hood Latch
!AIR
!EGR
!Washer Fluid
Painted bolts (cheap alternative to Specialized Stainless' bolt kit)
Painted Headlight Brackets - often overlooked in a Firebird
Painted Coil Packs
Likely some other things I'm forgetting...
Old Dec 17, 2008 | 10:00 AM
I dont have any pics of how i mounted it but i just bent up little pieces on sheet metal which i screwed to the car then velcro holds the cover on.
Old Dec 17, 2008 | 10:41 AM
fast01z28's Avatar
heres mine. i guess i dont have a completed pic that includes my specialized stianless covers.
Old Dec 17, 2008 | 10:47 AM
dennsterTA's Avatar
wire mod is one of the best things you can do to clean things up!
Old Dec 17, 2008 | 10:50 AM
Spd-Kilz's Avatar
Dennster, where is your battery cover from?
Old Dec 17, 2008 | 10:59 AM
dennsterTA's Avatar
Homemade. Some good thick sheet metal, some paint, and a ton of wet sanding. Got to make a new one though. Got lazy and didnt remove itwhen working on the car. Dropped a wrench on it and ruined it
Old Dec 17, 2008 | 11:41 AM
1995blacktattop's Avatar
Old Dec 17, 2008 | 12:46 PM
SPECIALIZED STAINLESS's Avatar
Old Dec 17, 2008 | 12:52 PM
Kingc8r's Avatar
Nice engine bays.......mine is no where near as nice
Old Dec 17, 2008 | 01:22 PM
riceburnerZ28's Avatar
how do u delete the washer fluid reservoir ? Do u totally eliminate it ? or hide it ?
Old Dec 17, 2008 | 01:34 PM
Schantin's Avatar
Here's mine.
To answer the inevitable - I spray painted the intake on my back deck. Took a day counting the masking. 4 months/ 4K miles later it looks exactly the same.
Still need to finish the wire mod. Been lazy
Old Dec 17, 2008 | 01:41 PM
km346's Avatar
very unique... Don't forget to put your rad. cap back on.
Old Dec 17, 2008 | 01:44 PM
Schantin's Avatar
Thanks. I took the pics in August right before the initial startup following my H/C swap. Wanted pics in case it blew up and ruined all the new paintwork! The radiator cap was off so I could add coolant and get air bubbles out of the system. Cap's back on now
Old Dec 17, 2008 | 02:49 PM
The Crazy Sweed's Avatar
Her is mine
riceburnerZ28: The fluid reservoir are gone.. I have to make a new one and locate it some were else..
Old Dec 17, 2008 | 03:02 PM
ls2 bait's Avatar
before the nitrous and a couple other odds and ends.
