Need help quick with overlays/ changing interior color to blue.
quickly learned to be careful! and yes it was VERY time consuming. it looks real good but now i am thinking about ordering silver overlays. so what i am wondering is if i remove the stock applique-will the overlays stay on without it? if the stock applique is needed-i just remove all the ink off of the applique, apply the overlay, and then the light will only shine through the overlay correct? BTW when you put an LED in the headlight ****. Will that make it light up now? If that is the case i want to do that soooooooooo bad but have no idea on how to do that.
Good luck.
I have gone Blue Led in mine as well. But like the above I cant solder for crap so I have not done the headlight switch yet either.
My friend has a mustang and he has alike a green film on the back of all his things that light up and we are in the process of sanding it off and making his interior lights red..
^^That might help.
https://ls1tech.com/forums/appearanc...ew-thread.html
I used the B8 series LED twist lock lamp for mine. I then cut it apart and used the resitor and bulb in it then soldered it so it would work. But since they have the NeoWedge id get one of those... I might pick one of those up.
^^That might help.
I thought MacEwens were clear also? Do they not replace the factory overlay (are they just stickers that go on top instead)?
