Where do yall get your HID's from??
"I've heard that these are difficult to install. Is this true? and are these illegal" - Iceman can
#34
All cars with OEM hid lights are within 4100-4300K range because it's the Kelvin temperature with the maximum useable light output. Beyond 4300K you start to lose lumens and the color becomes more white and then bluish and on to purple.
#36
No...these are not difficult to install. As long as you know how to at least strip wires and solder them, the installation is a snap. This is because you need to tap the LED halo into your car's wiring; I tapped into the fog lights. So when I turn on the fogs, the halos come on.
#37
4100-4300 is the brightest OEM light to my knowledge. If your going through aftermarket HID kits, usually 3000K-6000K-8000K and then up by 2's is usually only offered. I've never seen 4000K HID kits. Not saying that they don't exist, i've just never seen them.
As far as installation goes, the ebay kits that I've used and recommended to many are 100% plug and play (unless you have a firebird, you need to crimp a connector onto 4 wires and thats it)
#39
Don't buy the larger ballast as they are the old style and more prone to failure. Those are usually the really cheap ones you see on ebay. We only sell the smaller ballasts (which are about the dimensions of a credit card and 1/4 inch thick.
The kits are plug and play. No relays are included but you only need relays if your stock harness is not producing enough voltage to fire the HIDS. Generally GM vehicles don't need relays.
Bulbs #'s
98-02 Camaro Low Beam: 9006
98-02 Camaro High Beam: 9005
98-02 Camaro fog lights: 894
98-02 Firebird fog lights: 880
Bulbs #'s
