side molding
Old Jan 8, 2009 | 05:26 AM
98z8uup's Avatar
Default side molding
What is the best way to remove the side molding without hurting the paint. Thanks guys.
Old Jan 8, 2009 | 05:38 AM
wabmorgan's Avatar
Some say yank em'.
Or you could use fishing line.
Old Jan 8, 2009 | 07:51 AM
drewwrxrogers's Avatar
I also want to know the best way of removal! I think It will make my car look a lot cleaner! Serching hasnt turned much up. No writeups that I could find! Best I can think is use a heat gun and then use a eraser pad from like MR.clean followed by some light rubbing compound....?
Old Jan 8, 2009 | 07:52 AM
02gtp4now's Avatar
either grab and pull or using fishing line to slice it off.
Old Jan 8, 2009 | 08:57 AM
Iceman can's Avatar
x2...then make sure to get some goo gone and wipe off the rest
Old Jan 8, 2009 | 09:07 AM
Shockwave179's Avatar
Wait for warm weather and slowly peel them off.
Old Jan 8, 2009 | 09:42 AM
so the heat gun is not needed!? Just that simple huh...pull it off! Damn why didnt I think of that haha.
Old Jan 8, 2009 | 09:55 AM
homerunhtr21's Avatar
When I did mine I went
1. Heat gun for 10 min up and down the molding
2. Start with small piece in front slowly moving left edge first
3. Start at left edge on biggest piece slowly pulling down and to the right
4. Clay bar to remove the small amount of dirt/junk underneath the molding
5. Quick wipe down with a cleaner
6. Wax where molding once was
7. Step back and admire
This might take a little longer than just ripping it off but you will save time not having to scrape the glue that stuck on there because it was cold.
Old Jan 8, 2009 | 10:59 AM
NIGHTMAREWS.6's Avatar
I just starting pulling mine really slow, came right off with no problem, most of the goo came up with it, and didn't bother the paint at all, i did the side molding and removed my headrest all in about 20 min, easy mod i've done so far, go the excess goop up by rubbing it with my finger into a small ball and that was it, did harm the paint at all.
Old Jan 8, 2009 | 11:06 AM
^ Hmm..maybe I will try a combo of the above ideas! Does anybody have some before and after pics?
Old Jan 8, 2009 | 02:26 PM
Nick_Rapitis's Avatar
def use the heat gun and do like 1 foot sections at a time to keep the glue/tape warm where you are working...the warmer it is the easier the crap comes off...as for any left over glue heat it up and it should just roll up when you rub it...then use like goo-gone or something to get rid of any residue...followed by some wax and it'll good as new!
Old Jan 8, 2009 | 02:54 PM
98z8uup's Avatar
Thanks guys. I will give it a try this weekend.
