Will these fit a TA?
Product Line: Matrix Projector Sealed Beam Headlights
Part Type: Headlight Assemblies
Part Number: GRM-09-130
Headlight Style: Angel rim diamond
Lens Color: Clear
Housing Color: Natural
Quantity: Sold individually.
Notes: 4 in. x 6 in., accepts H-4 bulb. Not recommended for street use.
Headlight Assembly, Projector Sealed Beam, Angel Rim Diamond Style, Clear Lens, Natural Housing, Each
* Check to make sure this part fits your application
Get some real headlights.
If your ride came with ordinary round or rectangular sealed-beam headlights, chances are they're pretty lame excuses for lights. You can fix that problem in a hurry with Matrix's projector sealed-beam replacement headlights. They're available in both 5 3/4 in. and 7 in. round flavors, as well as 4 x 6 in. and 7 x 6 in. rectangular. They give you all of the advantages of projector-type lights, but pop right in where the wimpy OE lights used to reside. Readily available H4 bulbs are sold separately.
Back to Search Results
Do you have pics of these housings?
Almost all of the "projector" sealed beam housings are fake. Meaning its just a "projector-style" lens put into a regular reflector housing. There is no cut-off line, and the output is crap.
http://store.summitracing.com/partde...0&autoview=sku
I have no clue why the name says "projector" when they clearly aren't projectors.
Anyway... those should have output/beam-pattern similar to stock (possibly better), but allow the use of better bulbs which should be an improvement.
I wonder why it says "Not recommended for street use.".... I'd like to know how the beam pattern looks.
