Question about VHt
Old Jan 11, 2009 | 04:17 PM
Iceman can's Avatar
Default Question about VHt
Hey guys i'm in the process of doing my taillights and I was wondering if most people taped off the reverse lights when they did the VHT. I haven't seen anyone talk about that in the write ups.
Do you tape just the light of everything from the light over the end?
Thanks
Old Jan 11, 2009 | 10:29 PM
'02 WS6's Avatar
Thats what I did. Made, basically a ring of tape on the outside, and folded it over, then applied small pieces of tape to conceal everything. I did have a small bit go through on the outsides, don't know how though, but i got a bit of enamel reducer onto a paper towel and it came right off. Just take your time and make sure there are NO openings, and you'll be fine. Here's mine
Old Jan 11, 2009 | 10:40 PM
blackops22's Avatar
Ya just tape around the light.
I like it better without the VHT on the reverse lights because it adds to the silver theme on cars. Your car looks good '02 Double U S-6.
Has anyone done it that way on Camaro tail lights?
Old Jan 12, 2009 | 12:09 AM
EW1's Avatar
EW1
Love the tips on your car, who makes those?
Old Jan 12, 2009 | 10:00 AM
firehawk#682's Avatar
haven't done the tail lights but i would tape over the reverse lights
Old Jan 12, 2009 | 06:13 PM
'02 WS6's Avatar
I've seen them done to the Camaro lights, but only the LT1 style w/ the reverse in the upper left and right corners.
They're Mecham tips.
Old Jan 12, 2009 | 11:22 PM
Iceman can's Avatar
Thanks for the comments. Just one more question...did you tape off everything off on the inside of the reverse light.
Old Jan 13, 2009 | 09:25 AM
'02 WS6's Avatar
You don't want any of the white portion showing, if that's what you mean. While you may not spray it directly, overspray will definitely find its way onto there if you don't have it totally covered.
Old Mar 12, 2009 | 06:15 PM
JuStIn_Ws6's Avatar
Hey how many coats of niteshade and clear coat did you use on your taillights because thats about how dark I want them?
Old Mar 12, 2009 | 08:46 PM
my bandit's Avatar
what i did was find the widest tape you can then lay it over the whole section then take a razor and cut around it. you can see an indention and then just push down the tape on the sides.
i just did mine today
