An update on the Edelbrock coil covers.
#61
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Looks good so far!
Question: why the problem with #8, #6 spark plugs? Wouldn't they be connected before you put the coil covers on?
Which brings me to the question: how do the spark plug wires from the coil packs route? Do they just come out from under the coil cover edge and go to the plugs as usual? Stock length wires fit OK?
As far as the dipstick goes - you could have a slot milled in the edge of the cover in the appropriate place to allow clearance for dipstick to bolt in original position - or you could use a spacer with longer bolt...
-Jay-
-Jay-
#63
Looks good so far!
-Jay-
-Jay-
![](http://www.fquick.com/images/vehicles/full/14127233082.jpg?1234227730)
So the coils get mounted to the underside, then you bolt that whole assembly onto the valve cover. So you have a choice, either put the plug wire onto the plug first, then attach it to the coil, or vice versa. Either way is going to be a tough task for #6 & #8 since the heater box/hvac is right there. I'll figure it out though once I get to that point.
As for the dipstick, yeah, you could cut a groove, but I wanted to try and avoid hacking up the covers.
#68
The coils are essentially in the same location, it's just they are now attatched to the coil pack covers vs the valve cover. So there is no need to change plug wires. Just think about how tough it is to plug in the #8 plug wire currently and you'll see how covering up the coils will make it more difficult.
I should be able to reach up from the underside and connect the wires to the plugs.
#69
^ ^ ^ and for us guys that dont own a lift? lol ***. lol
alchemist where you get your lift and what you spend?
and you happy you got a 4 post. i know you park a car underit. but if you dint park a car under it would you have done a 2 post?
#71
![](http://www.fquick.com/images/vehicles/full/14127201723.jpg?1224464338)
As you can see, the garage is far from done, but it's functional. The bottom of the runners are roughly 5'11" as I just duck a little to walk under it and I'm 5'11". The bottom of the car is a good 6.5' from the floor.
#74
To have a 2 post, you need a lot of space as they are at least 12' wide. I've got a 20x20 garage with 2 8' doors, so a 2 post was never an option as it would have made it a one car and it would have been a nightmare getting the car on / off the lift due to the doors.
About the only isse with having the four post is being able to drop the motor out the bottom is more difficult than with a 2 post. Can it be done, sure, it just takes a little more thought and prep. There's a jack ramp in between so if I wanted to, I can raise either end and put it on jackstands pretty quickly. But for doing exhaust work, suspension work, and even swapping out a trans, it has made my life so much easier.
I paid just under $2000 for it, picked it up in Delaware and Andy (White.Lightning) along with a neighbor helped me install it in an afternoon.
It came in handy when I was doing the ceiling work in my garage as it's a 16 x 7 peice of scafolding that can raise and lower easily and is movable.
#75
Oh, and once the weather breaks, and I can get caught up on some crap around the house, I'll have a bbq for some of the local guys to come on over and play around on the lift. It is so handy in finding exhaust leaks and mystery rattles in the suspension and drivetrain.
#76
How high is your garage now from floor to ceiling? Did you have to remove the power door opener from that side? The one shown in the pic looks like its for the other door.
#77
Here's a good link showing what's needed to be done to convert from the typical opener with the rail in the center of the door to the side mounted opener with a high lift conversion.
Floor to ceiling on that side of the garage is now ~12 feet depeding on where you measure because of the pitch of the floor.
http://www.diygaragerepair.com/High-...oors-s/364.htm
#78
Well, here's an update on the passenger side.
As I thought, I plugged in the wires to the plugs first, then angled the cover in towards the back first and plugged in #8, then began to angle the front in and plugged in #6, then #4 then finally #2 when I slipped the cover over the oil fill tube. I definitely think the way to go is to install the coil pack cover with the intake off.
That's about as far as I got before the kids woke up from their naps, so more updates will be the next time I can get them both asleep. I'm going to try and keep the evap line where it's at and just route the line under the cover, but if that doesn't work, I'll have to relocate the evap line.
#80
Any chance you could have left the coil packs attached to the rails and the valve covers as normal and made a slight modification to allow the coil covers to attach seperately?
I realize the covers were made to have the coils attached underneath - but it looks as if the coil covers attach to the valve covers using existing bosses on the valve covers that are unused when the coils are attached underneath the coil covers instead of on the rails as stock. It may be that a slight mod will allow the coil covers to attach to the valve covers with the coils attached in the stock manner - hence, no problem connecting spark plug wires...
