Finally bright headlights for a T/A
Old Jan 20, 2009 | 08:45 PM
98legendws6's Avatar
My bad i get carried away. Im watching Max Payne while writing this. So it is hard to keep hiting enter to start a new paragraph. Lucky for me i can type without looking at the nubs. The first post was in paragraph form....i was paying more attention then..lol
WS6Jim's Avatar
Hey 98legendws6 I remember this site being mentioned here before. I just went with a eurolamps housing so I have the benefit of the h7 bulb. It was cheaper than your suggestion. I'm not saying yours isn't better but once you get things together in the car I'd really like to get your feedback and have pics.
Old Jan 20, 2009 | 08:56 PM
LSx Heaven's Avatar
I would like to see them as well
Old Jan 20, 2009 | 09:01 PM
wannafbody's Avatar
Well they should update their website. The $200 price will scare most people away.
Old Jan 20, 2009 | 09:02 PM
VIP1's Avatar
Copy & Paste Moderator
For those who are wondering the address of the site.... google the company name. Its the first link. Its also where I bought my projectors. For a further hint.... check out the "Projectors - & Other Headlight Upgrades" section of the Lighting FAQ. Check out the Lighting FAQ anyway for more info on lighting upgrades in general.
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Old Jan 20, 2009 | 09:17 PM
There are tons of upgrades available of course. I havent found any info on the eurolamps housings, and H7s will do the job as well. I really like the fact that these are a direct GM upgrade part. Just not available here in the states. Isnt it great. All the Jap cars keep the best stuff in Japan, but the US sends the best stuff overseas....HMMMMMM
I of course will keep everyone informed with the progress and pics all around. Feel free to PM me with any questions and HOPEFULLY i will be able to see clearly now that the old lights are gone. lol...
Old Jan 20, 2009 | 09:33 PM
TXws6's Avatar
Originally Posted by TORCHD 02 TA
please post your installed lights in this thread..
+1 post up!
Old Jan 21, 2009 | 12:36 AM
Disturbed Bird's Avatar
for $350 i can get hids with projectors and installed. but thanks anyways.
Old Jan 21, 2009 | 05:12 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Part No. HLHCSL150 150mm Headlamp Kit
I used the Eurolamps housings with H7 bulbs and PNP wiring harness adapters - but had I know about these years ago I would have went with them...
Old Jan 21, 2009 | 08:46 AM
TORCHD 02 TA's Avatar
The pricing is wrong on the website. they are cheaper than 350
Old Jan 22, 2009 | 08:11 AM
Logic's Avatar
watching this thread
Old Jan 22, 2009 | 08:57 PM
  #32
Recieved everything today, only took 2 days from when i placed the order. AWESOME!! The wiring harness is great. The housings are beautiful...well as beautiful as stock ones i suppose. Hope to get to work on everything this weekend.
Old Jan 22, 2009 | 09:01 PM
  #33
can you take some pics of what you have now so that we can see??
Old Jan 22, 2009 | 10:24 PM
  #34
Randy WS6's Avatar
Old Jan 22, 2009 | 10:41 PM
  #35
wannafbody's Avatar
The Eurolamps uses a H7 which is smaller than the H4 used in this kit. Will an H4 bulb put out more light since it is bigger.
Old Jan 22, 2009 | 10:45 PM
  #36
VIP1's Avatar
H7 has only one filament and is low beam only, which is fine for the low beam location on the 1998-2002 Firebird. Having an H4 bulb in that location is pointless since only the low beam filament will be used unless you do some re-wiring. Comparing the low beam filaments only, the H7 has a higher output.
H4
Low: 910 lumen, 50 watt
High: 1500 lumen, 60 watt
H7
Low: 1350 lumen, 55 watt
High: N/A
1350 lumen is a lot more than 910 lumen.
If you want to be technical, the Camaro's stock 9006 low bean bulb is brighter than the H4's low beam filament.
9006
Low: 1000 lumen, 55 watt
High: N/A
You can get a "hyper" H7 which is basically a H9 capsule on a H7 base.
H9 is also a low-beam-only bulb.
H9
Low: 2000 lumen, 65 watt
High: N/A
These specs are from Sylvania's regular Halogen.
Now comparing to HID..... HID is typically 3200+ lumen (depending on OEM wattage and bulbs versus some higher output aftermarket).
Old Jan 22, 2009 | 10:48 PM
  #37
wannafbody's Avatar
So if you want to upgrade only the lowbeams then the Eurolamps kit is the best option?
Old Jan 22, 2009 | 11:02 PM
  #38
VIP1's Avatar
Well that depends on the beam pattern. If it has a good beam pattern then the housing that uses H7 bulbs will be better.
I can't say for certain which of these two housings is better because I haven't seen the beam patterns of both housings for comparison. There were a couple threads a while back in which InfiniteReality said that he didn't like the beam pattern of the eurolamps housings. I didn't see any beam pattern pics comparing both housings though. Maybe he has some pics somewhere he can post. The pic I saw had HID installed in the eurolamps housings and the beam pattern was indeed bad, but then again it was HID in a Halogen reflector. He switched to some Bosche housings (I think they are the ones in this thread), but I couldn't find beam pattern pics. He said that he liked the Bosche ones better, but he put HID into them which is comparing apples to oranges when talking about H4 vs H7.
You could always use upgraded wiring with a relay to install higher wattage H4 bulbs in the housings. Just make sure to use upgraded wiring and that the bulbs really are the higher wattage and not fake (most are).
Old Jan 23, 2009 | 05:34 AM
  #39
White.Lightning's Avatar
Pics or bust
Old Jan 23, 2009 | 06:07 AM
  #40
tasilver's Avatar
Subscribing
