High Temp Paint For Whistler Mod?
Old Jan 26, 2009 | 06:50 PM
98RedBird's Avatar
Default High Temp Paint For Whistler Mod?
Just wondering If I'll need a high temp paint when I do the whistler on the car? Not sure how warm it will get in there with the lights. I've had paint bubble and flake off a set of T/A Fogs that I did in the past.
Thanks guys
Old Jan 26, 2009 | 07:56 PM
hlaalu's Avatar
nope.
Old Jan 27, 2009 | 02:56 AM
jrenfrew0606's Avatar
shouldnt need to unless you are using hids. they tend to get aq little hotter than regular lights
Old Jan 27, 2009 | 10:35 AM
hlaalu's Avatar
unless you already have some regular plastic paint around the house, then just get some high temp paint when you buy some for peace of mind
Old Jan 27, 2009 | 10:55 AM
fast01z28's Avatar
high temp paint is not needed. regular spray paint is able to take the heat of being in the sun, which is hotter than what your headlights will do.
i do recommend using a water based paint though. When i did the whistler headlights it looked great for a month or two, but then i started getting this oily residue on the inside of my lenses. i removed the lenses and cleaned it, but that lasted a month or two again, and now its back.
I hear this is a common issue with whistler modded headlights.
Old Jan 27, 2009 | 02:15 PM
GTABurnout's Avatar
Wrong they actually run cooler but need more poewer to light...
I haven't had this happen yet but I can believe that some out gasing can occur in the light if they sit in the sun alot...
Old Jan 27, 2009 | 02:55 PM
Cobra2WS6's Avatar
Never had that happen to me eaither... Just make sure its gloss black!
Old Jan 27, 2009 | 03:01 PM
hlaalu's Avatar
i wonder if a clearcoat over the paint would help that?
Old Jan 27, 2009 | 03:10 PM
FlashLCD33's Avatar
Like fast said up there.. clear will have the same effect.
Old Jan 27, 2009 | 03:16 PM
hlaalu's Avatar
he said he cleaned it, not cleared it. unless i misread something?
