Painted trim on pop up lights.
Old Jan 27, 2009 | 08:38 PM
*WILDSTYLE 5.3*'s Avatar
Default Painted trim on pop up lights.
Im sure there are some people out there that have painted the nasty black trim around the 99+ T/A's headlights but i couldnt find any threads on this. Does anyone know of any or if you did paint yours to match the color of your car how did you do yours? Thanks guys im thinking of doing this to mine b/c i hate the black trim.
Old Jan 27, 2009 | 08:44 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I painted mine pewter to match the car... came out ok, not the exact shade of the bumper, but much closer than the black.
Let me see if I have any pics.
Old Jan 27, 2009 | 08:53 PM
Pics would be great. how did you do them. prep and such... and you just used a spray paint can? clear also?
Old Jan 27, 2009 | 08:55 PM
98 WS6's Avatar
If your going to do it, it's easy. just pop up your headlights, then switch the parking lamps so their not blinding you while you work. Take out I think 3 screws on each headlight shroud, then take them off and shut the car off.
Go to your local auto store and get Duplicolor "Adhesion Promoter Primer" it should have a clear top. This is good for painting on plastics. Get whatever color paint you want, you can find the codes online, Duplicolor also. Also you could get a clear coat paint can if you'd like for added protection and gloss. Just make sure your clear matches what kind of paint your using. For example, if your using Duplicolor GM Bright Red Enamel, make sure to get Enamel Clear coat.
All you need to do is 3 coats of the adhesion promoter, 2 or 3 coats of color, and 2 or 3 coats of clear. You won't need to sand it at all (unless it's a bit messed up) and clean it up with alcohol or something.
Old Jan 27, 2009 | 09:05 PM
Sounds good thanks for the info 98 ws6 i think im going to try this tomorrow. im going headlight crayz i already ordered the 4 headlamps from SUBSQUEHANNA MOTORSPORTS i saw you posting on the thread about them did you end up buying a set 98 ws6?
and if you can find some pics that would be awesome Alchemist.
Old Jan 27, 2009 | 09:11 PM
f-bodyguy's Avatar
take out the 3 screws as stated sand paint clear the only time they will be seen is in the dark so i would just get close as i could...dont take that as a smart *** reply
Old Jan 27, 2009 | 09:20 PM
98 WS6's Avatar
I actually have full HIDs in my 'Bird, so I don't really need a set of those lights lol. They look to be pretty nice though, they seem to be brighter. Although I dislike the look of halogen lights (the yellowy shade kills me) so I don't know if I would have gotten them anyway. I made a writeup on how to do HIDs for Firebirds, but it's great to know there's finally another option to go with. Stock headlights SUCK in birds. If you need any more info on the painting too just let me know. Each can of paint should be $5 as well
Old Jan 27, 2009 | 09:51 PM
96blackta's Avatar
None taken. i mean yes it is a "diffrent question" b/c i mean i prob will rarly see them but just one of thos to be diff mods i guess? anyways thanks for the info guys.
Old Jan 27, 2009 | 09:54 PM
98 WS6's Avatar
Noooo problem, take pics after/if you do it
Old Jan 27, 2009 | 09:59 PM
Runamuck's Avatar
I did it on my LT1 bird I used to have.
Old Jan 27, 2009 | 10:18 PM
97ramsst's Avatar
I am not a fan of painting the black plastic part around the headlights, but I am going to take mine back out (I have all the brackets chromed already) and paint the black metal headlight assembly (that you can see whith the hood up and the headlights down) SOM to match the car. It should be subtle but match the bumper support I already painted. I will do it and post some pics when I get a chance.
Old Jan 27, 2009 | 11:26 PM
phantomzer0's Avatar
I did mine in gloss black and they came out great. Not sure where the pics are, let me look.
Old Jan 27, 2009 | 11:35 PM
Found!
Old Jan 28, 2009 | 12:04 AM
98 WS6's Avatar
Looks good Russ!
Old Jan 28, 2009 | 12:54 AM
Tanks!
Old Jan 28, 2009 | 02:38 AM
CRAGER's Avatar
Administrator
Originally Posted by 98 WS6
Looks good Russ!
+1 Good job!
Old Jan 28, 2009 | 06:57 AM
UNDER PRESSURE MOD
I'm still searching for pics. They could be on one of three different computers, so it may be a little while. I'd take pics, but the car is in hibernation right now.
Old Jan 28, 2009 | 07:37 AM
LS1crazy01's Avatar
Hey what kind of paint did you use? I never thought about doing this but maybe I will, Im gonna subscribe this thread so I can see your pix first.
Old Jan 28, 2009 | 07:57 AM
LS1nut377's Avatar
hmm i like the gloss black. very nice! gives those headlights some much needed touch up.
beleive i will do that in the near future!
