disable auto headlights
Old Jan 28, 2009 | 10:37 PM
robster's Avatar
Default disable auto headlights
anyone know how to disable the automatic headlights on a 02
Old Jan 28, 2009 | 11:12 PM
nemss1's Avatar
i removed the sensor, cut the 2 wires right before the sensor and spliced the 2 wires together
some people use u scotchlock which does the same thing
Old Jan 28, 2009 | 11:13 PM
nemss1's Avatar
oh ya, light sensor is in the vent on the top of the dash next to the blinking red alarm light
Old Jan 28, 2009 | 11:17 PM
VIP1's Avatar
Copy & Paste Moderator
Sticky: https://ls1tech.com/forums/7096661-post8.html
Old Jan 28, 2009 | 11:18 PM
SparkyJJO's Avatar
If you don't want to do a permanent disable you can unplug it and use a piece of wire in a U shape plugged into it instead and leave the plug with the wire in it hanging under the dash. That way if you want auto headlights again just remove the wire jumper and plug the sensor back in.
I think I'm going to do this when I take my dash pad off to fix my dash sag. It is annoying sometimes to have my headlights click on when I pull in the parking deck for a minute, and with the HIDs now I don't want the constant on-off when not necessary.
Old Jan 29, 2009 | 11:21 AM
Scammper's Avatar
What about keeping the fog lights on when the brights are on? I had my 95 set up to do this... just grounded out the relay. Then you could run brights and fogs at the same time. Can this still be done on the 4th gens... Havent tried it yet.
Old Jan 29, 2009 | 12:04 PM
robster's Avatar
awesome. ill do that. and im wondering about the fog lights too
Old Jan 29, 2009 | 12:46 PM
2002 SS's Avatar
thats what i did. super easy
Old Jan 29, 2009 | 02:07 PM
VIP1's Avatar
Sticky:
https://ls1tech.com/forums/appearanc...same-time.html
https://ls1tech.com/forums/stereo-el...y-brights.html
Old Jan 29, 2009 | 02:10 PM
Havok2's Avatar
search works guys '
Old Jan 29, 2009 | 02:27 PM
98noscamaross's Avatar
Just pull the e-brake up one click!
Old Jan 29, 2009 | 08:43 PM
SparkyJJO's Avatar
Then you always have the brake light on in the dash. Or, in my case, the switch doesn't work very well (gotta pull my console apart to clean it).
Old Jan 30, 2009 | 11:34 AM
robster's Avatar
yea mine too. sometimes my lights come on when i turn the key on and the e brake is still up
Old Jan 30, 2009 | 12:08 PM
nemss1's Avatar
cutting the redish-orange wire behind the light/dimmer switch also disables auto lights
