Will any drag race front wheel fit with Baer 13in Track kit?
I have the Baer track kit with 13inch rotors and PBR calipers on the front of my 96SS.
Anyone know what kind of skinny front wheel would work with these brakes?
C4 vettes have the same brake setup, maybe something is made for those cars?
The Baer track kit just uses a C5 caliper on a 13 inch rotor.. so your problem isnt spoke clearance so much as it is clearing the rotor.. I would think that you would be hard pressed to fit a 16" rim on the 13" rotor/caliper combo.. The best thing would be to find a tire shop that carries the wheel your interested in and test fit the wheel to your brakes.. You could also get the template from Baer and use it to check wheels..
Good luck..
Good luck..
