brake calipers
Old Jan 31, 2009 | 09:26 PM
TUCKZ28SS's Avatar
Default brake calipers
so even after hitting my calipers with a wire brush/sanding tools, and then cleaning with prep-all the paint just wont stick to them. This is frustrating the **** out of me. What do you guys use to take all the residue off? Do you use primer first?
Old Jan 31, 2009 | 09:35 PM
fbodyrs96's Avatar
what kind of paint are you using, I just cleaned and painted 4 coats with the brush on paint that's it.
Old Jan 31, 2009 | 09:45 PM
k0261886's Avatar
My guess is that you are doing this in a unheated garage? You aren't supposed to paint under like 50 degrees.
Old Jan 31, 2009 | 09:52 PM
TUCKZ28SS's Avatar
true it is kind of chilly in there, and i am using high heat gloss black paint
Old Jan 31, 2009 | 10:33 PM
screamin96ss's Avatar
Yea if the metal is too cold it won't allow the paint to set up properly.
If not having a clean surface is the problem try cleaning them with brake cleaner then laquer thinner.
Old Jan 31, 2009 | 10:59 PM
Magic Man's Avatar
I brushed them up real good then used brake cleaner then painted them.
Old Jan 31, 2009 | 11:17 PM
LT1-Camo's Avatar
yea def try paiting them in a warmer place...i cant wait till i get my new rims...im gonna paint my calipers gloss black and get silver camaro decals for them...matched with some new slotted rotors should look nice...what color are you painting yours
Old Jan 31, 2009 | 11:29 PM
hlaalu's Avatar
did you use a metal primer first?
Old Feb 1, 2009 | 07:29 AM
Flaring Afro's Avatar
i just sprayed some brake cleaner and rubbed a bit with a towel. wasnt hard at all. i used the paint from the duplicolor kit thats liquid and did it in the summer though.
Old Feb 1, 2009 | 07:38 PM
Blacked_Out_SS's Avatar
i just sprayed brake cleen on there then hit it with an air nozzle then sprayed the **** out of them with regular gloss black spray paint..... it has been good for the year and a half that i've owned my car...
Old Feb 1, 2009 | 11:50 PM
01CaMMMaro's Avatar
I cleaned mine with aircraft remover.
Old Feb 12, 2009 | 10:52 PM
barnat's Avatar
Default Heres mine for sale
Ide say give up and just buy mine LOLThere ready to go !!I paid a body shop to do mine!
http://s243.photobucket.com/albums/f...t/brake%20kit/
