interior/exterior modifications
Oh and honeycomb tailights(much better)
At least...on LS1 cars, that's how it is...I don't see why it would be any different on a '93 - '97.
prep/paint the rotor hats/drums (correctly, with it off the car) so they don't show rust
learn to wash/polish/wax/detail your car properly! this is KEY for appearance! it is cheap (once you have wash mitt, soap, and wax/polish). a clean car is what helps appearance the most. you'll have to do this at home with at least a few hours to spare:
- clean tires with preferred tire shine
- hose down with water
- make soapy water bucket
- microfiber wash mitt in soapy water bucket
- rub car down with soapy microfiber wash mitt, rinsing soapy microfiber with clean water bucket after a pass
- clean wheels with separate rag and soapy water
- hose down car again to remove soap
- rinse car off with low-pressure hose water to make drying easier (make the water collect)
- dry car with one old, soft, clean bathroom towel that wont be used in the bathroom (think raggedy edges). one is enough.
- dry wheels with clean rag
- use car polish (you can use Nu-Finish if you're afraid of polishing compound)
- after polishing, use car wax (meguiars nxt 2.0 or zymol if you need cheap)
- if your wheels are painted, polish/wax them as necessary, since it is paint just like the rest of the car.
now as far as cheap/easy/quick mechanical upgrades...
replace any worn bushings/mounts. im sure if your car is a 97 you will have some that are worn out.
replace worn belts, and any other maintenance items (fluids, plugs/wires, brakes/noises, etc.)
if you want to do swaybars, now would be a good time to switch them out for some take-off V8 swaybars from a junkyard, too while replacing the bushings at the same time. not too expensive and a very good upgrade for a V6 car. any 93-02 V8 car has bigger swaybars (and bushings) than your V6. SS/WS6 has a better front bar but even "standard" Z28/Trans Am bars are acceptable.
Inserts are personal preference and vary depending on the theme/feel of the car. Your choice...
For fog lights you can try and fab up something from an autozone/pep boys/oreilley/walmart fog light kit. It takes some time and materials though. Somebody probably has a write-up on here...
For wax I use Meguiars NXT 2.0 liquid or paste (purple container), clean terry cloth towels to apply, and those bright yellow microfiber towels to remove. If that black triangle thing behind the side windows needs some refreshing (and the paint is still halfway-good) you can try and shine it up using Nu-Finish (orange bottle) and waxing it. Nu-Finish also "works" as a chrome polish. If for whatever reason you don't like Nu-Finish as a car polish to remove light blemishes, you can try hand-buffing with plenty of 3M Polishing Compound and then wax. If you polish it and the car goes dull again after a couple days (or doesn't shine up at all), then your clearcoat is shot and will have to be redone.
I use Eagle One tire shine and the separate foam applicator. I should have bought the one with the foam applicator built into the bottle... Every once in a while I take the wheels off and clean the insides with a wet rag I don't want any more (trash), as well as cleaning off the calipers/suspension with an old wet sponge (also trash). I say trash because I don't like the idea of rubbing brake dust particles and road debris into the paint of the car when re-using that rag...
Don't waste any money on the current car and save for mods on the LS1 if you get one!!!!!
