Draglites, what can I run in the front?
I have saw too many 3.5" draglites break the welds or crinkle up or warp. So here's my question can you put say a 15x5" draglite on the front? Also can our cars handle a 15x10 for the back so I can run 26x11.5x15 ET Streets or will the 26x11.5x15 fit on a 15x8 draglite? I think the 11.5 will have to be on a 10 inch wheel. Thanks
Brian
Brian
Re: Draglites, what can I run in the front?
Man, I can't believe you asked that question. I just purchaced 15" X 5" Weld draglites. I have the 3.5" for the track with the 5/16" spacer. I thought the 5" would fit with the spacer. WRONG I had to grind the calipers. I still have the spacers on for now but I'll grind some more later to get them to fit without the spacers. I hope they will fit without the spacers with a little more grinding. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Man I just got in from the garage. I was grinding for hours.
I got the 5" so they will be street legal. 3.5" and 4" are not. I have the MT Sportsman fronts mounted on them. I also have an extra set of 15" X 10" Weld draglites with MT Sportsman Pros for the street.
Good Luck
Tom
Good Luck
Tom
