Rear camaro pannel
I would like to see what it looks like, the theme of the car is no badges, no anything on the outside...
Just a heads up if you do it. Don't just fill in the lettering with filler. I filled in just the letters at first and sanded it down smooth and put two coats of primer down annd you could still see the wave/outline of the lettering. I ended up stripping it back down and trying it again and same effect. Finally I layed filler across the entire panel to get one uniform smoothness and finally got the glass like finish I was looking for.
I've seen some pics of others doing the same and having the same outline effect and thought I would pass some info your way to help save time and possibly money if you have someone else do it.
