Painting Bumper Supports
Old Apr 2, 2009 | 01:11 PM
Kingc8r's Avatar
Default Painting Bumper Supports
I've tried searching this topic but nothing comes up.
I want to paint the bumper supports on the front of my Camaro black. I also want to paint behind the headlights...
Do I just scuff these pieces up with an SOS pad. Do I need primer? Regular black gloss or gloss high temp paint?
Thanks for the Help.
Pics or links to write ups will help as well
EDIT: here are some pics. I ran out of paint so I'll do the headlights when I do the whistler mod
Old Apr 2, 2009 | 01:26 PM
99zee's Avatar
I didn't scuff it up. I put on a couple coats of primer and then sprayed the support flat black. You can paint it on the car or take it off. The support comes out pretty easy. I ended up coming back later and spraying clear over it. Which ruined the "flat" look. Thats before I knew about the clear that will protect AND leave the flat look.
Old Apr 2, 2009 | 01:27 PM
mattl31's Avatar
i'd scuff them up real good with some 600 grit or so, and do a good wipe down with thinner or some sort of solvent. let that dry do i quick wipe with some tack cloth and hit it with some high quality satin black spray paint like duplicolor. id suggest against gloss black just because it wont be nearly as easy to make look good on an imperfect surface like that.
Old Apr 2, 2009 | 01:28 PM
Kingc8r's Avatar
Thanks for the advice. Where can I get tack cloth?
Old Apr 2, 2009 | 01:29 PM
Kingc8r's Avatar
So Primer isn't always needed?
Once again thanks for your help
Old Apr 2, 2009 | 01:53 PM
Spd-Kilz's Avatar
99zee: that looks great! I'll be doing that when my coolWhip comes out.
Old Apr 2, 2009 | 02:30 PM
99zee's Avatar
Any autoparts store or Walmart
Old Apr 2, 2009 | 03:29 PM
98redM6's Avatar
I'd use primer for some more durability. I know it isn't really exposed to anything that could chip it but with some heat, over time it could start to flake.
Old Apr 2, 2009 | 10:07 PM
blertawho's Avatar
Krylon Fusion satin. I pulled everything apart and just wiped them down with some paint thinner. I should have used a gray scuff pad, but i didn't feel like going to the store and getting one. Just made sure to do a nice light tack coat before really laying it on.
Old Apr 2, 2009 | 10:36 PM
Kingc8r's Avatar
^ Damn! That looks good
Old Apr 2, 2009 | 10:51 PM
LETHLS1's Avatar
did it a long time ago, big visual improvement! a little dust on it...
Old Apr 4, 2009 | 12:27 AM
Kingc8r's Avatar
Finished product.....
