Aftermarket Halo install around Projector fog lights on my Formula...
Copy & Paste Moderator
Originally Posted by CALL911
I'm not really sure what the cutoff shield is.
Typically a low beam is stepped: _____/-----------
Typically a fog beam is flat:_____________
I'm guessing you left it as a low beam pattern or did you buy a fog light version of the projector?
It still has the cutt-off shielf inside of the projector. However they are aimed so low its hard to see the cutoff line. I will be adjusting them sometime to aim them a little higher, thats when I'll try to get the pics. I'm pretty busy usually (currently in USAF pilot training), but I hope to get this done sometime this weekend.
I adjusted them today (haven't checked them out at night yet). Unfortunatley, as I suspected, the area was WAY too small to get my camera to fit into. I could have taken pictures aiming up into them from outside, but it would not have shown any of the bracketry or how they fit. Sorry.
I love the look of the Hellas with Halos. The light output was a bit better just by going with the H4 bulbs in the projectors. About a month ago I installed some HID's though and now they are KILLER, but just aimed a bit low (which hopefully is fixed now
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
H4? I don't think there is an H4 version of any projector since H4 is dual filament. Did you mean H7 or H9? (I know the Hella 90mm comes in H7 & H9 versions. What's the part number of the ones you have?)
That halo ring does look good there. It helps fill the gap around the projectors since they are a little smaller than the opening in the bumper.
I just added this thread and your other thread from March to the Firebird Fog Light section in the Lighting FAQ.
CALL911 - do the 120MM use H9's as well? I read your earlier thread when you installed the projectors and you said that 90MM produced a gap which you later filled using a Halo. Is this the 120MM you were referring to that was out of stock at the time http://www.rallylights.com/Hella_120...p_Modules.aspx ? And I'm thinking that I need to replace my 880's for H9's once I purchase the projectors correct?
If you do end up getting a set of fogs that utilize the H9's, and want a good deal give me a PM. I can give you a good price on my H9 bulbs. I only had them in the car for a short period of time, and they still are in new condition.
#32
Hey Call911, do you have HID low beams as well? I have HID low beams and installed HID fog lights as well but I kept burning out the accessories fuse and my radio was all funny. What style of HID fogs did you use? Single or dual ballast system?
Your car looks great btw
