How to "diffuse LEDs"
Old Apr 30, 2009 | 08:42 AM
Joshiedoom's Avatar
Default How to "diffuse LEDs"
I installed a LED into my dash last night for my toggle switches.. Its all hidden and the squish dash hides everything EXCEPT for the fact that the LED has more of a straight beam instead of a diffused light that will spread over the switches... any coating, paint or substance I can paint over the LED with to get it to diffuse?
Old Apr 30, 2009 | 09:37 AM
blackbyrd's Avatar
they make wide angle led's but they are replacement bulbs like a 194, im not sure what you replaced though are you talking about the security light on the dash??
to help disperse the light better i have used plexi before it travels through it similar to fiber optics, the edge of the plexi that is not clear and scratched where it has been cut will catch the light for a wider angle, but not knowing which light you have replaced i dont know if thats an option
Old Apr 30, 2009 | 09:51 AM
99_Z_155's Avatar
Jam a piece of wax paper or something in there.
Old Apr 30, 2009 | 09:55 AM
Joshiedoom's Avatar
Ill probably do the wax paper idea. You cant see the LED unless I turn it on.. I did some googleing and with the write wording or words I found out can can sand the LED and get it to do that.. I sanded the hell outta it but its a nice dam LED so its still straight as an arrow for the most part.
I bet superglue will do it as well because it will fog the hell outta it if I put a nice smear mark over it... It looks like the red bulbs that are in the side of the doors so it looks completely stock to the untrained eye.
Old Apr 30, 2009 | 11:02 AM
FamousZ's Avatar
So are they like indicator lights? Like when you flip the switch they come on? If so why not just get the LEDs that are made for that? They are not super bright..
Old Apr 30, 2009 | 01:51 PM
Joshiedoom's Avatar
No, I installed a LED over my toggles switches where the TCS would be on a trans am(dont have tcs). It was shining straight down on to the ashtray lid(a4) instead of shooting light everywhere around the switch.. cant really tell what is doing right now.. way tooooooo bright.
Old Apr 30, 2009 | 07:57 PM
99_Z_155's Avatar
another thing you can try is hot glue. its easy to work with and it can kinda get the same effect. ive done alot of led's on the old xboxes. i used wax paper and hot glue both.
Old May 2, 2009 | 01:59 PM
futuref-body's Avatar
put it up to a belt sander. no belt sander= rubbing it fast on a file. will disperse light much better.
Old May 2, 2009 | 02:50 PM
Casper9T9's Avatar
Yeah. Just sand the tops flat.
