Rotor & Caliper Painting
As far as sanding and cleaning go, should sand paper (paper and dremel rolls) and break cleaner be sufficient to smooth and clean the calipers?
I am also planning to paint the hats and edges of the rotors black before I put them on. Should I do anything to the rotor before painting? I plan on scuffing them in the painting area, but Im not sure if the coating on the rotors will interfere with the paint sticking.
I plan to paint using Duplicolor red caliper paint for the main calipers. For the brackets and rotors I was debating using POR15. I have seen people use that but I wasnt sure if it had enough heat resistance for the area.
That about covers it. Any other tips for doing this would be greatly appreciated
http://www.g2usa.com/
POR15 works good for those areas, I have used it but it will chip if you don't prep the metal behind it.
BillyB- Ive never heard of anyone priming before using the caliper kits. Have you done this before painting and how did it turn out? I will be using the ceramic paint kits, not rattle can for the record.
Thanks for all the tips, keep them coming.
The reason paint doesn't last very long on calipers(yes including the G2, it'll fail way faster than powder coating every will) is the lack of strength and flexibility. Your caliper constantly heating up and cooling down makes it expand and contract a bit. Paint can't handle this, it looses its bond both to the metal and to itself and starts chipping off. Powder is so flexible that this will never be a problem, along with superior chemical and heat resistance.
You get what you pay for. Before I got into powder coating, I tried everything under the sun to keep my calipers looking nice with paint, nothing ever worked. And the car was not by any means a daily driver during this time either.
He's right.....I attempted to paint my rotor hubs with "high temp" caliper paint..EPIC FAIL!
The rotors have been stripped of all paint and will soon be in the hands of Silver Ghost who did a kick *** job on my calipers & brackets.
I was really confused for a minute 'cause your avatar really looks like my car lol
98WS6- Ill take that as a a compliment. Ive seen pics of your car and its definitely a nice car!
Good example, 8 years old.. I did this when I first got the car.
I used Duplicolor caliper paint. so we will see how it holds up. Currently everything is drying right now. Plan on putting it all back together tomorrow
here is a real qucik bad pic. you can see my finger prints
I just cleaned with brake cleaner, sanded with 150, whiped down with wax and grease remover and sprayed. I cant even scratch it off, it seems very durable, however, i would powder coat them if i had the money
Not me personally, but a few customers. Then again, they may not have done it correctly, who knows?
