Engine appearance questions
Old May 19, 2009 | 01:43 AM
thecobrahunter's Avatar
Default Engine appearance questions
I'm planning to relocate the driver's side air hose underneath the shock tower. In the picture attached, I show where I want to drill the hole. Is there any risk of structurally weakening the tower by drilling here? Where else have people drilled the hole on their car? And yes, I'm keeping the air system...I live in CA and the emissions people around here are dic*s.
Also, I want to replace some of my pulleys, but can't figure out what the (2) little pulleys between the A/C and the crankshaft pulleys are.
Old May 20, 2009 | 07:18 PM
What? No one knows what these pulleys are, or they just don't want to say...
Old May 20, 2009 | 07:24 PM
hlaalu's Avatar
no risk at all to the well there. and i think those two pullies are tension pullies?
Old May 20, 2009 | 07:27 PM
Justins00ss's Avatar
yeah those pulleys are just tensioner pulleys
Old May 21, 2009 | 12:22 AM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
Just tell people they are built in twin superchargers right in the block! Suck you gotta keep the AIR system
Old May 21, 2009 | 02:04 AM
Okay...tensioner pulleys...got it.
And yeah, it does suck about the air system.
Thanks!
Old May 21, 2009 | 12:30 PM
hlaalu's Avatar
honestly i would take out the air system, just disconnect it before the pump so you can easily plug it back when you need to pass smog or something. it makes it look so much nicer without it.
Old May 21, 2009 | 06:36 PM
Okay...
so I disconnect it at the air pump. What about the rest of the hose(s) connected to the engine. I'd have to take out those, too. And what about setting off any codes?
Old May 21, 2009 | 06:57 PM
hlaalu's Avatar
yup you can take those hoses out as well and get some plugs. it won't set off any codes as long as you leave the pump in. the pump will still turn on and your car won't know the difference if the tube is connected or not
Old May 22, 2009 | 12:13 AM
prince xizor's Avatar
I just did this. I drilled my hole below the metal triangle piece so it would be on a flat surface. I had to add some heater hose to get it to fit. I basically did the !wire mod but on the driverside. I think I used a 1" ID grommet and a 1-3/8 hole saw
