installed new shifter (pics inside)
1. locate the staple facing the front of the car that holds the shift **** in place, pry it out with needle nose pliers/small flathead.
2. this is what the shift lever looks like without a ****, the metal sleeve and inside is the plastic shift actuator.
3. the adapter slips over the lever and only fits one way so just twist it around until it fits in place. there are two small hex head screws that need to tighten around the plastic part, it takes an alan wrench (2 metric)
4. **** slides over the adapter, make sure you have both screws tight enough that they are flush with the adapter otherwise the **** won't fit all the way. finished product!
Haha I said shaft.
And yes, all you do now is push the ball down, it does the same job as the button on top of the stock ****.
