Progress Report
Old May 21, 2009 | 07:44 PM
Spd-Kilz's Avatar
Default Progress Report
I've slowly been throwing some parts on, and making some changes to the car.
Here are some pictures...
McNord Gauges:
Wideband / Shiftlight:
Vent Gauges:
Polished Exhaust (before/after):
Painted STB (Reppin' PHK):
Removed Rear Bird and "Firebird":
Redid DRL's (Before/After):
LOTB Badge & Drilled Rotors:
Old May 21, 2009 | 07:53 PM
firehawk#682's Avatar
Very nice you have been busy. I like all the gauges!
Old May 21, 2009 | 07:55 PM
mattl31's Avatar
wow man thats really looking good. love the gauges, very viper-esque.
what rotors are those? like them?
Old May 21, 2009 | 07:59 PM
TORCHD 02 TA's Avatar
damn Adam you have been busy. Looks good.
I like the LOTB badges, is that a dragonZ28 badge? If so which ones are they?
Also you have been spending some $$$$
BTW do you have any night shots of the gauges lit up
Old May 21, 2009 | 08:06 PM
03_r6's Avatar
very nice man, I have a soft spot for formulas, looks like yours is coming along nicely.
Old May 21, 2009 | 08:15 PM
hey adam how did you get the paint nice and smooth on the STB?
Old May 21, 2009 | 08:22 PM
raptorws6's Avatar
The new additions looks great man.
Old May 21, 2009 | 10:24 PM
Spd-Kilz's Avatar
Thanks for the comments guys!
Thank you! I picked them up from Powerstop's Group Purchase. I have nothing but good things to say about them. They look great, and I've had no problems with them.
Jonas, the badges are not from DragonZ28. I picked these up before I knew he was going to offer them. PM me if you'd like a link. They are quality badges though.
Most of the stuff I bought over the winter and have just gotten around to installing it now, or was virtually free (DRL's, paint etc).
I'll post night pictures in my next post.
Sand with 1000 grit | Primer | Light coats of paint | Wetsand 2000 grit | Clear
Old May 21, 2009 | 10:25 PM
Spd-Kilz's Avatar
Here they are at night.
Just for the record, I still need to get red LED's, along with red needles.
This is how it will look with the stock lighting.
Old May 21, 2009 | 10:32 PM
Blacked_Out_SS's Avatar
damn.... looks good... your car is so clean and nice... how hard was it to do the gauge overlays?
Old May 21, 2009 | 10:47 PM
Adam one more thing, how did you polish your your DRLs??? Those came out great.
and i think i am going to have to re do my STB. it is all chipped up...
Did you wet sand your color after your last coat?
Old May 21, 2009 | 10:55 PM
It is easy. going off the top of my head
Remove the kick panel (i think it is 2 phillips screws and 2 7mm or 8mm bolts)
Tilt the wheel all the way down
remove tilter by unscrewing it
remove bezel (pops out) do not pull it all the way out
find the wiring harness for the fog light switch and dis connect it
now remove the (4) 7mm or 8mm bolts on the corners of the bezel
tilt bezel so that it is at an angle to get out. It will be tricky
Next unplug the 2 wirng harness in the back of the gauge pod
once in your hands, unclip the plastic lense from the bezel
Now you have access to your needles
Old May 21, 2009 | 10:56 PM
you should have swapped the lights when you had the bezel apart. Now you have to do it all over again
Old May 22, 2009 | 07:56 AM
Spd-Kilz's Avatar
Thanks! Very simple. Follow the steps TORCHD laid out for you, along with taking off the needles, removing the old GM overlay, putting on the new one, and putting it all back together.
I took off the lenses covers, sanded the inside then painted it with chrome paint. To finish it all off I cut out the new lenses from a sheet of lexan, and then siliconed them in. I'll post some pictures.
Yes. Wet sand after the last color coat. I didn't wet sand the clear coat.
I had to take out my whole gauge cluster the other night and take off the original gauge overlay so that I could remove my Service Engine Soon light, since I had an Emission Test the next day. I figured that I might as well install the new gauges while I was at it. I still don't know what LED's to get yet. Really though, it's not all too difficult to do.
Old May 22, 2009 | 07:57 AM
Spd-Kilz's Avatar
Here you can see that one is still "factory", and the other one was sanded, then painted with chrome paint.
Old May 22, 2009 | 10:38 AM
LS1Zedder's Avatar
Did you have to replace your stock metric guages for those overlays to work?
Old May 22, 2009 | 11:27 AM
Spd-Kilz's Avatar
The car is American so it came with MPH and the small km/h. I don't mind converting in my head (regardless of it being illegal).
The gauges are offered in Kmh if you'd prefer it.
I hope that answered your question.
Old May 22, 2009 | 02:01 PM
tbird31's Avatar
Those gauges in the vents look familiar...lol
Glad you finally got those in there, they look really good man.
Old May 22, 2009 | 06:06 PM
I have a suggestion for your leds I used these and am very happy with them!!
5 of these for the gauges WLED-xHP6 Wedge Base Bulb
I also went a set further and one blue (brights indicator) and 2 amber ( turning signal arrows) Leds for my gauges too. WLED-xHP High Power LED bulb
Here is what they look like now. No bright spots at all
the turning signal and bights indicators arent shown in the pic tho
Old May 22, 2009 | 06:19 PM
'Trust''s Avatar
I take it the factory overlays just cover a large light source and that is how you guys have lighted logos? That is freakin sweet!
