How can i make the fogs stay on with the hi beams?
I JUST finished my HID install...hi/lo's and fogs...and I was wondering if there is any fairly simple way to make the fogs stay on when I turn the high beams on (its a Trans AM by the way)? I know on a Ford truck its simple as jumping two wires in the fuse box...whats the secret on a TA?
(And before any BS gets started its a show car...they will only be on at shows...yadda yadda yadda...dont get into it blinding people and so on.)
So your one of those ******* that blind me an almost make me run off the road at night with my wife an kids in my car!! LOL joking i have hids in my z28 The wire for the fogs to stay on on the 98-up camaros is the light green wire under the fuse block that has the fog light relay in it. Lift the box up which is under the hood. Cut the wire off run the wire that comes from the fuse block to the ground which is right there. Tape the other end off just so its not just dangling around. might not hurt nothing but still. Im pretty buzzing right now. but i will double check it in a few. Pretty sure its the ame as for the trans am as the camaro
this method worked perfect for my TA foglights. https://ls1tech.com/forums/stereo-el...y-brights.html
