Tropi Care summer specials
I think I may finally take the dive and get a complete car care kit from you.. I've been using the entire line of Meguires products for a long time with great success but I think it's time to step it up to the next level.. Do these kits come with a basic rundown on what each product does and what to use when? I also may need to get a new PC, mine is a bit old.
LS1TECH Sponsor
TORCHD:
I actually use both varieties and others depending on the task. The foam wash mitt is either the ShMITT or Ulti-Mit. With the white/yellow exterior use ShMITT, the surface dirt readily rinses right off the face of the mitt.
SOMSS1LE:
Each product is pretty straightforward and has basic use instructions on the label. You can reach me here or toll-free for additional guidelines.
BAD30th:
Feel free to contact me with any questions once you get started.
SOMSS1LE:
BAD30th:
I had always used a MF mitt. When Steve sent me the new foam ones, I used it to see how well it worked and liked it. To me the foam mitt holds more suds and seem to "glide" on the paint better. I still use the MF mitt on certain areas and vehicles, but use the foam mitt most of the time.
