Covercraft vs. CalCover (Indoor only)
Which cover will best fit my needs? Does one get the nod over the other? Car will be kept in the garage at all times except for when I am driving it. Is it pretty much six one, half dozen the other?
if its inside, it doesnt matter. i have a $5 nylon cover from ebay that works perfectly fine since its always inside. the only advantage of an expensive cover is they are thicker, and may protect from bumps/dings. other then that, all you need an indoor cover for is a dust barrier. nylon does that just as good as anything else.
