Need help!......tire fitment problem! (long)
Back to the problem. I have some 18x10 billet specialties wheels (running 295/35 tires) that I recieved last week the day before the Hot Rod Power Tour (should have received them way sooner, but that is a long, long story in itself). The backspacing was 7.25" leaving 2.75" in front of the mounting surface. I know that some guys running 17x11 with 7.75" backspacing (3.25" in front of the mounting surface) claim to have no rubbing problems. I thought I would play it extra safe and give myself a half inch more of quarter panel lip clearance by going with a little more backspacing. Well, anyone with a Pro-kit that claims to not rub with 315's on 11-inch wheels must know something I don't because on my 10-inch wheels with extra backspacing and 295/35's, I rubbed so bad on the quarter panel wheel well lip that I had to run the Power Tour on my stock 16-inchers. Trust me, I was not a happy camper. What can I do? These wheels were expensive and I have to make them work. By the way, the car "looked" completely awesome when the wheels/tires were on the car. The combo of the stance and wheel/tire package was excellent. If only it didn't rub?.....
Here are the options I can think of (please feel free to suggest others):
1. Put stock springs back on and hope that the suspension travel is not enough to still allow rubbing.
2. Try another set of rear springs from another Pro-kit and hope they do not lower the car as much.
3. Try a totally different brand of lowering springs. However, the only other companies with mild drops that I know of are G2 (1"/1 5/8") and Hotchkis (1"/1").
4. Roll the wheel well lip. I hate to do this on a brand new car (2002 Z28), but I guess you gotta do what you gotta do.
5. See if Billet Specialties can adjust to backspacing by machining the mounting pad or moving the center section out.
<strong>1. Put stock springs back on and hope that the suspension travel is not enough to still allow rubbing.</strong>
Should work, but may make the rear of the car too high, could always cut them.
Risky gamble
SLP Eibach rear springs will give you 3/4" to 1" drop. This is what I am running. Mark is running these springs with 315's and an 11" rim, but he does get a little outerwheel well lip rubbing, when the car is loaded or during EXTREME accelleration.
May just have to do.
I don't feel it is necessary to do this, I am running 295 series tires on 18" x 10.5" Z06 style wheels with a 7.75" BS and a 5/16" spacer to get the wheels out further, I also have the SLP Eibach springs on my SS. I have NO outer wheel well rubbing problems, did rub a little on the inside before the spacers.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<small>[ May 30, 2002, 10:59 AM: Message edited by: Xsta Z 28 ]</small>
I am just going to re install my stock springs in the front and adjust the HALs for the drop I want.
I am going to cut one full coil out of the rear springs and see where that puts me. I will take a little more out if I need to.
I am really pissed with my Pro kit because that was the whole reason in getting them, to have a mild drop so I could still run an 11-12" wide wheel on the back.
<strong>Xsta Z28
So, of your suggestions which one would you most likely try first.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">HMMM, I guess I would go cheapest/easiest first.
1. Reinstall stock springs. Free mod less your labor.
2. Cut the stock springs, going half a coil at a time, and reinstall, luckily rear springs are very easy to install and only take about an hour to do. Free mod less labor and possibly some cut of discs. I cut my front SLP Eibachs to get just a little more drop. See pictures here: Camaro Picture Album
3. Find a suitable replacement rear spring such as the SLP Eibachs. Unfortunately I do not know if you can buy just the rear pair.
4. I wouldn't even try to buy another set of the Pro Kit, it plain and simply is too low.
5. A very cheap "testing" step could be to buy the coil spring spacers from places such as Auto Zone, just to see how much height you really need. The little "twist-in" kind, but as I said ONLY for testing. Cheap mod. I did this on my old 81 Z that literally fell to the floor with the lowering springs I put in. The car actually sat on the fenders.
6. Have the wheel modified if possible, but I don't see this as necessary.
7. Absolutely last have the rear fender lip professionally rolled.
I hope that helps.
Andy
