GM SUX!!!!!
Well mine was and had a shi*y job of covering it up! the drivers door was dinged or somethin and they repainted it and got over spray on both before the door on the quarter panel and behind the door on the read panel! its like a dull clear coat.. in the sun u can see that the whole door above the side molding is a more faded black then the rest of the car.. also when u open the door its on the end of the door where u can see they tryed to mask off and its bunched up and cracking.. on the actualy car where the door shuts theres a line down the out side of where they once again tried to mask it off but did a S$%T job! this is reallyt bugging me and would it be coverd on warrenty? the body work is also off center.. the door rubs at the front top corner on the quater panel and the door handle rubs the door whenever its opened.. the paint is whereing off in these places...o ya and i noticed that the clear coat on the door is peeling off now to! what should i do? is there a way i can check to see if the car was dinged on shipping?? will GM cover it on warrenty?? and GM is also screwing me around because i sent in my application for the warrenty card and havent received it after 2 months! is this right?? <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Andy
I had a small fender bender and we took it to the body shop and it took them a month and a half to fix it the first time and then when I got it back it had a different rim on it and a LONG scratch down the passanger side door and the front, left headlight had some sh!tty paint work(lots of runs). So it went back in the body shop for another month and a half!
If I didn't have bad luck I wouldn't have any at all.
Josh S.
this is done at the plant but usually a better job than you explained.
and each state here is different but in connecticut the damage must be over $400 before it has to be made note of although most reputable dealers will make darn sure it is noted in paper work to avoid just this type of issue.
good luck i hope you get it fixed to your liking as it should be
If so you have 12months 12kmiles to report cosmetic DEFECTS for GM to cover it. I work @ a GM dealership. I say defects because if it is damage they may not help you. They will tell you that you should have looked it over before delivery. I work in parts now but used to sell Pontiac's and GMC's and you would not believe how many people bring cars back and lie and say "o it was there" when 9 out of 10 time it wasn't there when they bought it. So lieing cheap people screw it up for everyone. Just be nice and pationt with the dealer and try to work it out. And if that doesn't work calling GM and b*tching and b*tching does get stuff done.
but new the guy i baught it off of and he said he has never hit nothin.. but i still don't understand the part about my warrenty card?? we filled out the transfer paper perfect and mailed it right away! which was around apil 1... so whats with that?
