Got Bitten
I went to Radio shack and bought a push button switch. You could just as easily use a toggle. Fiind your wires under the center console. The PINK wire is the trigger for the power antenna. Clip it, splice in your button, and mount the button. I drilled a little hole in the side of my center console, down by my knee and mounted it there. Done.
Thanks for teh mention...that does look good.....
Liek he said for you folks that are gonna cut your antenna...remember to pop off the ball you can re-set it after you cut your OEM and DO cut it a multiple of your antenna orginal lenght..you get better reception that way
I run a CUT down OEM when ever someone steals my BVModded antenna or I sell it off my car...
