gum on seatbelt, need help
Other thoughts Goo Gone, Goof Off, or Brake Cleaner (Naptha = dry cleaning solution)
Found this at "Ask Jeaves":
Chewing Gum
Scrape away as much as possible first. Rubbing the stain with ice will harden the gum and make this easier, especially on rugs and other heavy materials. Refer further under Candle Wax
If the material is washable, soak in kerosene and wash in hot soapy water. For unwashable articles, use dry cleaning fluid. Several applications may be necessary.
Try using an icecube to freeze the gum, then pick it off bit by bit. You may have to apply the ice several times before you get it all off. Good luck.
Be sure to let us know what worked.
