Polished calipers, now new question...
Old Jun 6, 2002 | 05:10 PM
zZAndrusZz's Avatar
Default Polished calipers, now new question...
Finished polishing my calipers, now I wanna polish the visible edge of the mounting bracket and support. Is it easy to take the caliper and mounting system off? Or is this just something I should leave alone? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Andy
Old Jun 6, 2002 | 08:26 PM
Xsta Z 28's Avatar
Default Re: Polished calipers, now new question...
Very easy to diassemble. the are tow bolts that mount the bracket to the car, just make sure to torque the bolts down to spec and use a little loc tite, I've heard of the bolts coming loose.
Old Jun 7, 2002 | 05:27 AM
zZAndrusZz's Avatar
Any idea what the specs on these bolts are? No manual handy. Another thing, is it very hard to bleed the system back to normal??
Thanks again.
Andy
Old Jun 7, 2002 | 08:29 AM
Xsta Z 28's Avatar
You should be able to take it apart with out dissconnecting the caliper, from the brake line, the caliper unbolts from the bracket, then just hang it with a piece of wire. Then remove the bracket from the support. Polish the bracket.
Troque spec. I want to say 74 ft. lbs. BUT PLEASE DOUBLE CHECK!
Bleeding our brakes is just like any other normal car, open bleeder on caliper, have some one pump the brakes until fluid comes out and move to the next. Start with the caliper furthest away from master cylinder. Don't forget to keep checking master cylinder so it doesn't run out of fluid.
Old Jun 7, 2002 | 10:24 AM
Steve1969LS1's Avatar
The only problem with polishing the mounting brackets is the fact that they are not aluminum.. they are steel.. and steel really dosent polish well (and theres that rust problem <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
My advice would be to have the bracket chrome plated.. it will match the caliper pretty good and be MUCH easier to maintain <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Good luck and post pics when your done <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 7, 2002 | 11:31 AM
Mark IXZD 150's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Steve2000SS:
<strong>The only problem with polishing the mounting brackets is the fact that they are not aluminum.. they are steel.. and steel really dosent polish well (and theres that rust problem <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
Good luck and post pics when your done <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, or paint them silver with Duplicolor 'cast aluminum'. Chrome of course would look much better but Steve is right, they'll look like crap without the proper coating. That's why they have that zinc coating on them from the factory.
Old Jun 7, 2002 | 01:57 PM
zZAndrusZz's Avatar
Going to end up painting them, atleast they will match the calipers better, I'll post pics when I'm done. Thanks guys
Andy
Old Jun 7, 2002 | 02:33 PM
zZAndrusZz's Avatar
What about clearing them? Would this stop the rust problem? Or would it be better off to just paint and forget...
Andy
Old Jun 7, 2002 | 05:41 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by zZAndrusZz:
<strong>What about clearing them? Would this stop the rust problem? Or would it be better off to just paint and forget...
Andy</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">They will only rust if you remove the cad plating.. Sure you could clear them after you polish them but I dont think you would get very good results polishing steel.. its not like its stainless steel.. The BEST results would be to chrome.. the second best would be to paint.. silver, Charcole grey (cast iron) or an accent color would be your best bets.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 7, 2002 | 05:44 PM
zZAndrusZz's Avatar
I'm going with painting them "aluminum" I plan on getting fm5's in polished later on, so chroming them would be a waste in my opinion. They are looking pretty sweet if I must say, I'll snap some pictures tomorrow or sunday.
Andy
Old Jun 8, 2002 | 12:08 AM
Bambeezer's Avatar
Sounds like you're going to have a sweet set up. I need to do something with my brackets too. Be sure to post pictures when you are done.
__________________
2002 Pontiac Formula A4
The Fikse-Mobile
12.54@106.91mph on a 1.69 sixty foot
Vigilante 3200 converter, lid, ported MAF and tires. FUll stock exhaust.
http://formula.bambeezer.com
brandon@Bambeezer.com
