ASR switch for other usage?
Old Jul 1, 2009 | 03:52 PM
Havok2's Avatar
Default ASR switch for other usage?
i have read/heard ASR switch can be used for other accessories.
like a purge
if i were to wire it to use it as a purge, what wires do i need connect or so
i just need to know which wires were used as ground/power/switch on?
or is the ASR considered a monetory switch i can use as a purge?
any help is appreciated, wanna wire my nitrous system using ASR as a purge, and an extra fog lamp switch as a Nitrous Arm switch
Old Jul 3, 2009 | 05:53 PM
Havok2's Avatar
so nobody has this mod done?
Old Jul 3, 2009 | 05:59 PM
hlaalu's Avatar
i dunno cause there are a bunch of wires running to it. do some testing with your switch and see what wires do what.
Old Jul 3, 2009 | 07:27 PM
Duffster's Avatar
I don't remember the wiring on it, but it's here. . .
https://ls1tech.com/forums/stereo-el...or-opener.html
Originally Posted by marc1130
I am trying to upgrade my '95 switch to a '97 switch for a firebird.
here is my switch:
Here is the '95 wiring:
Here is the wiring shown above, my '97+ tcs switch plug looks the same as the asr switch, it seems like i just need to add the grey interior lamp wire. Can i just rewire using this diagram by adding the grey interior lamp wire? Is a 97+TCS switch the same as an asr switch?
Old Jul 4, 2009 | 12:18 AM
scj's Avatar
scj
i'm also interested in this, i'd like to wire up an asr switch for an electric cut out
Old Jul 4, 2009 | 05:14 AM
6LITEREATER's Avatar
I use one for a purge and one for a garage door opener. Did the install years ago though so I'm afraid I don't remember wiring. I remember it was a bunch of trial and error.
Old Jul 4, 2009 | 09:32 PM
Havok2's Avatar
i need 3 wires right?
power
ground
switch?
Old Jul 4, 2009 | 10:46 PM
Duffster's Avatar
and 1 if you want the light to light up. . .
