How to Remove the Passenger Air bag cover
No you cant . If the bag was never popped, if you pull off the foam cover, the plastic portion is still "apart" of the dash . There are just relief cuts so it breaks right when the bag is popped . Given the locations of the screws that hold the pass. airbag in, the dash has to come out ~or unbolted enough to get sufficient clearence to the screws and to pull it out .
