I've got a question on mini-tubing.
I'm looking to run 18x11.5 Profil 13's with 335's on the rear of a '98-02 camaro and I would like to know about doing a mini-tub. I prefer not to do it as I'm not planning to race the car. Although I may at some point try an autox once at some point. But it's going to be a DD so I wasn't wanting to chop up the car but if it's what I have to do to fit the wheels & tires, then I will look into it.
My question is can I have the tubs only come in an inch or two or are they pre-made with pre-determined dimensions. I will only need a slight amount more of clearance (about an inch or two) over stock to fit the wheels/tires. I'd like to hear from others who have done it or know about this. And if anyone has pics, that would be great.
I want to be able to keep the rear seats & hatch area as stock looking (I will be putting in a Wolfe 8-point roll cage though) and functional as possible. I have seen the Wolfe Racecraft mini-tub kit and it appears to be available with a small one like I'm looking for.
What would the ballpark cost be to actually have it installed? Thanks.
Why did you decide against it? If I can fit the wheels & tires with just doing the bfh mod I'll do that but I'm not sure if just that would be enough. I don't want to have any rubbing or not look very good. The wheels will have to be able tuck in right, just inside the wheel well or almost flush.
https://ls1tech.com/forums/drag-raci...ight=mini+tubs
