Whistler Mod Help
well yesterday I tried to do the whistler mod... I popped out one headlight and I put a large flat piece of stone in my oven to put the headlight on as I didn't think it would be a good idea to place it directly on the oven rack... I had it in there @ 200* for a good 25 mins and the damn lens would hardly budge... I stuck it back in for another 15 mins and same deal... the lens would hardly budge.. and i didnt want to try forcing it against the housing as i heard it was very brittle and could break easily... I didn't wanna keep trying so I let the headlight cool down and tossed it back on my car so I could drive around last nite.
My question for those of you who have successfully completed this mod is: did you place your headlight directly on the oven rack or did you place something in your oven... what i'm thinking is since it was a fairly large piece of stone (large not THICK - prolly 2-3cm thickness) it was absorbing most of the heat especially since the temp was only 200*...
Thx guys
EDIT: 225 for 30 minutes worked perfect for me.. Both of mine came right off without any issues.
one thing i did notice is that my drivers side headlight is not OEM it says TYC on it... maybe they're using a different silicon than the OEM ones???
It was difficult for the first one so I turned the oven up to about 250 for the second one. left it in for about 18 mins and it came off much easier than the first. Not sure if this would help you any but it worked pretty good for me.
