LED Turn Signals (Very Easy)
#42
well, i did everything, including the EL12 Flasher and every single light in the car is flashing with the turn signals when parking lights are off, and nothing flashes at all when the parking lights are on... they do light up though.. only problem is turn signals..
any clue?
any clue?
#47
FrankSS: major prop's man that's a cool idea and looks pretty sweet to me i might try my hand at that when i get time, im going to try and tinker around with idea's but mainly use your idea and build around it from there. Now Either way man nice job looks good and be safe out there..
#50
Thanks! Everything works great, no diodes, no load resistors, etc. All I needed was to separate my short in the bulb. The parking lights and turn signals have to be separated (in the bulb). And the only thing I made sure to have was that EL-12 LED Flasher unit. It had another number on it, but it's the equivalent.. Cf12.. something...
#55
1 Post
Yeah I read that can't wait to see! I was only searching for a pic of swapping LEDs for bulbs but found that a bulb will be brighter than a single led. But then saw this, looks alot better wish I could do it but I don't have the ends $ right now for that haha.
#57
Going to bump this up. Thanks to FrankSS for this idea,
i went on search for empty bulb base/socket for 3157 bulb in our DRLs and found this.
I ordered it, and what it seems like I 'll be able to the wire the led strips into this base and plug into the factory drl socket.
so my next question is that since LEDs draw less power than regular bulbs, does the car think that a bulb is out since all the power isn't being used by a led strip that a regular bulb would use?
Will I again need a power resistor to keep the turn signals from "hyper flashing" as the LED's will draw far less current than the filaments did...
