Offset / Backspacing question....
Old Jun 27, 2002 | 04:15 PM
SPANKY LS1's Avatar
Default Offset / Backspacing question....
How do I measure the offset of a wheel? I assume that I can lay a straight edge across the back of the rim, measure from the mounting surface to the lip and !BAM! backspacing measurement...am I correct? (I assume that backspacing is the same as offset????)
Old Jun 27, 2002 | 10:01 PM
MIGHTYMOUSE's Avatar
Default Re: Offset / Backspacing question....
yes. but i think offset is from the front to the middle.. and backspacing is from the back to the middle..
either way.. add an inch of backspacing for every inch added to the wheel width. this will keep the outside edge of the wheel in the same spot in relation to the body.
