How to buff Trans am Tail Lights?
Old Aug 15, 2009 | 12:29 AM
fbodyman1026's Avatar
Default How to buff Trans am Tail Lights?
The tail lights on my trans am have gotten a lot of swirls in them over time and I want to make them look new again. What procedure and product should I use. I do have a porter cable also.
Old Aug 15, 2009 | 12:50 AM
InTheHawk23's Avatar
cut and buff them 1500 wet and the use 2500 wet and then some rubbing compound and buff i used to do it all the time at the shop i used to work at the results are very good they look brand new after just don't burn the plastic
Old Aug 15, 2009 | 01:38 AM
98 WS6's Avatar
Polish them just like you would your paint. If they're really bad and you want them to look BRAND new, sand with 1500/2000 grit then polish the hell out of them. They look great when they're done. You can also use this method on your filler panel if it's a little worn.
Old Aug 15, 2009 | 04:21 PM
imaprobassangler's Avatar
Yup I did this to my tail lights and center piece about 2 months ago.. still look brand new, got rid of any swirls or anything like that. I wet sanded with 1000 then 2000, then washed off with regular water to get rid of any dust left from sanding. Then used some cutting compound with a wool pad on a buffer and hit it with some machine glaze from 3M with the buffer after that. Looks like a mirror when your done. I did all of this with the lights still on the car, makes it easier to handle, just tape off where you don't want to hit and I threw a sheet over my trunk with it up so no splattering got inside my car.
Old Aug 16, 2009 | 12:49 AM
LS1-MEX's Avatar
i mastered the light restore game......start with 1000 grit wet then bump up to 1500 grit wet.....then use a rotary and rubbing compound and then use a polish then a nice sealant......and your good to go
Old Aug 16, 2009 | 02:44 AM
99Ls1fever's Avatar
Good Info Guys!!! My WS6 Light Filler Panel is needing the love. Nice Post
Old Aug 16, 2009 | 10:59 AM
qwk93ta's Avatar
I'm going to have to try this....I have a scuff on my driver's side tail light that I want to get out.
Old Aug 16, 2009 | 11:02 AM
tspence45's Avatar
I'm also going to have to try this. My passenger side tail light looks a little darker than the drivers side for some reason. Plus, my filler panel needs some love. It's got a few scuffs on it.
Old Aug 16, 2009 | 06:13 PM
Scira's Avatar
This works great. I took my time doing mine, but it was well worth it!
Old Aug 16, 2009 | 07:46 PM
Tom565's Avatar
Check out this post:
https://ls1tech.com/forums/appearanc...il-lights.html
