How to remove the Y87 kit.
Any help is appreciated.
As for your question, they should just be on their with double sided tape and in a plastic lip that they slide down into.. The rockers are on with a couple of screws and plastic rivets as well. If you remove all of those and pull up and away on it, then they should come off, as long as the double side does too.. you will still have the plastic track that is screwed to your car though.. you can remove them, but you'll need to get the holes filled and painted if you want it to look good..
bolts are 10mm i think. its a long process. i want to remove my spoiler and just get a stock z28 one. let me know if u remove your spoiler, i want to know how hard it is.
