17x9.5and 18x10.5 zo6
Old 07-09-2002, 11:20 PM
JameSS's Avatar
Default 17x9.5and 18x10.5 zo6
im looking at getting 17x9.5front and 18x10.5rear chrome zo6 wheels. i was thinking of running 275/40/17 up front and 275/35/18rear. Does this setup sound like it would work?? And what would be the right offset to get on these wheels?? Thanks for the help. James
Old 07-09-2002, 11:41 PM
Intelman34's Avatar
Default Re: 17x9.5and 18x10.5 zo6
You need a 295/35/18 for the rears. Stock front size is 265/40/17 but a 275/40/17 should work fine. A 265/35/17 is 25.3" tall and a 275/40/17 is 25.7" tall.
<small>[ July 09, 2002, 11:47 PM: Message edited by: Intelman34 ]</small>
Old 07-10-2002, 12:19 AM
JameSS's Avatar
thanks i thought that 275/35/18 would be alright but i guess not
Old 07-10-2002, 08:49 AM
CamaroCain's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JameSS:
<strong>thanks i thought that 275/35/18 would be alright but i guess not</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Those WILL work, that is what I have on my car because i can't afford the 295's.
Old 07-10-2002, 10:15 AM
Xsta Z 28's Avatar
The tires you list will work, but on the 10.5" wide rim I would highly recommend the 295/35ZR18 rear tire, it just fits the wheel better, appearance wise.
Old 07-10-2002, 10:42 PM
JameSS's Avatar
just picked up my zo6 wheels today!!! 18x10.5 rear with a 58mm offset and 17x9.5 in the front with a 56 mm offset i think. im getting the tires put on tomarrow so i hope everything fits OK. I am thinking of doing the 285/35/18 rear and 275/40/17 up front..
Old 07-11-2002, 03:21 PM
JameSS's Avatar
the rears are a little tight with the inner fender wheel. does anyone know how to fix???
Old 07-11-2002, 04:32 PM
Xsta Z 28's Avatar
<strong>the rears are a little tight with the inner fender wheel. does anyone know how to fix???</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">A BFH and some undercoat.
Old 07-11-2002, 04:52 PM
VSGLS1's Avatar
I used the sledge hammer mod...works quite well
Old 07-11-2002, 08:29 PM
JameSS's Avatar
sweet sounds good, do you bash it in where the inner fender pops out?? i dont want to mess somethig up
Old 07-12-2002, 08:33 AM
Xsta Z 28's Avatar
<strong>sweet sounds good, do you bash it in where the inner fender pops out?? i dont want to mess somethig up</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My suggestion is to drive the car around for a while with the wheels and tires on, you will here some rubbing and scuffing, the noise sounds aweful, but nothing major is occurring. Then you will see all the areas where the wheel (actually the tire) rubs inside, then take your BFH and pound away. Re undercoat, and then drive again, if you still hear rubbing repeat. Hope that helps.
Old 07-12-2002, 09:26 AM
JameSS's Avatar
Alright i will do that. thanks for alll the help.
Quick Reply: 17x9.5and 18x10.5 zo6
