AC Knobs
Old Aug 31, 2015 | 02:01 AM
  #101
LT4vert's Avatar
Originally Posted by The Alchemist
Sounds like some hot glue might be my friend.
With the type of plastic these ***** use, epoxy would bond very well. Im with VIP, hot glue would not be good in the long run.
Old Sep 7, 2015 | 10:31 PM
  #102
1sicLS1's Avatar
Default AC *****
Any updates??
Old Sep 8, 2015 | 05:16 AM
  #103
The Dragon's Avatar
Question
I ordered a set from one of the links posted and they do NOT fit.
The d-shape was way too big and too short.
Which set actually fits?
Old Sep 8, 2015 | 06:04 AM
  #104
The Alchemist's Avatar
UNDER PRESSURE MOD
I got the *****, and yes, there needs to be some modding to get them to fit. I haven't had much time to do anything with them, but I will post some pictures when I do.
Old Sep 8, 2015 | 07:54 PM
  #105
VIP1's Avatar
Copy & Paste Moderator
We all said that they wouldn't fit without modification.
You need to modify them.
Old Sep 8, 2015 | 11:46 PM
  #106
The Dragon's Avatar
Lightbulb
Nope.
Actually someone in this thread posted that some of the ***** fit right on BUT that the D-shape would be 180* pointed in the wrong direction.
I couldn't care less about modifying the D-shape 180* for the ***** to point in the proper direction but these ***** I received have too large an opening.
Definitely all ears to how they can be modified otherwise I'll just junk them. Only 12 bucks anyway.
Lesson learned
Old Sep 9, 2015 | 09:47 PM
  #107
VIP1's Avatar
You probably bought the ones that I posted which I said were 180* the wrong direction AND too large.
Old Sep 11, 2015 | 08:35 PM
  #108
BirdsSince16's Avatar
I got some in and they were the ones that were too large. I had a second HVAC panel and set of ***** that I had no qualms modifying and just cut the part that goes into the HVAC unit level with the back of the **** itself on both. I then made sure they were perfectly flat and used PlasticWeld to attach the back of the stock ***** to the Mazda ones.
I removed one of the switches from the back of the spare panel and used the hole as sort of a jig. I wrapped some paper around where the plastic weld was so the **** wouldn't get stuck in the panel and placed it in there to make sure they fit and lined up correctly and let it dry overnight in that position.
The next morning I pushed it out through the back of the panel and removed the paper. The plastic weld as cured and I tested it on the switch I removed to make sure it wouldn't shear off or fall apart. All was well and I installed them on my actual car. Been working great for a couple weeks now.
I'll post pictures of the finished product when I have a chance. Wishing I'd taken pics in-progress.
Old Sep 23, 2015 | 08:52 PM
  #109
86_irocz-28's Avatar
Finally bought mine to although I have a little more planned for them
Old Sep 26, 2015 | 09:32 AM
  #110
UNDER PRESSURE MOD
One down, 2 to go.
Old Sep 26, 2015 | 10:48 AM
  #111
1sicLS1's Avatar
Wow, that looks good. Any write up or is it pretty straight forward?
Old Sep 26, 2015 | 10:33 PM
  #112
VIP1's Avatar
Can you post info & pics of how you modded them? I have 2 boxes (3 ***** each) sitting on my desk for the last few months. (car is in storage) I was going to try and either get or make a metal insert the right shape/orientation and fill in the gaps.
Old Sep 27, 2015 | 12:41 AM
  #113
vikingramair's Avatar
One down, 2 to go.
That looks real good!!
Old Sep 27, 2015 | 05:21 AM
  #114
UNDER PRESSURE MOD
I didn't take pictures, but I can explain what I did.
So the first thing is you need to cut off the plastic rim around the outside of the **** to get it to fit flush.
Then I used some gorilla glue and filled the back of the **** where it slides over the metal tab on the hvac panel, and put a screw in to take up some of the void.
After the glue setup for a few hours, I was able to remove the screw, and then insert the metal 'D' shape tang from the factory **** and let the glue harden completely.
I'll try to grab some pics as I do the 2nd and 3rd ones.
Old Sep 27, 2015 | 06:32 AM
  #115
Double-aught_Z/28's Avatar
Hmm, I may have to give this a try.
Old Sep 28, 2015 | 01:56 PM
  #116
VIP1's Avatar
The Alchemist, sounds like what I was thinking although I wasn't sure about removing the extra clear lip at the back.
[EDIT]
I don't know what I was thinking, but the ones I have don't have the clear lip at the back. The box says they are for a Mazda 6 (M6). The ones I have might be bigger.
Old Sep 29, 2015 | 09:18 PM
  #117
***** came yesterday already started on them a/c ***** mocked up headlight switch is installed and works great have a little more planned for the ***** than alchemist
Old Sep 29, 2015 | 09:28 PM
  #118
SparkyJJO's Avatar
They look bigger than the ones Alchemist got.
Old Sep 29, 2015 | 09:38 PM
  #119
I think so to the ones I got are full metal I don't mind them for there size although there the same shape design
Old Sep 29, 2015 | 10:22 PM
  #120
LT4vert's Avatar
For this style **** there are several different sizes depending on the model theyre for. Kudos to the guys doing this. It looks good and I will be doing it soon.
