Restored Camaro Headlights With Pics!!!!
I think its the UV that breaks down the plastic. You may clean them up, but eventually with enough exposure to the sun they will fade again...just look at any car with plastic lights sitting in the junk yard. Unless the lenses were made out of glass, they will fade/fog.
Deluxe Headlight Restoration And Sealer Kit
Info on the kit:
Cloudy sun damaged headlights not only look terrible but are also potentially dangerous for night driving. Cloudy sun damaged headlights cut down on the actual light projected from the vehicle to the road nearly 50% which gives you less time to maneuver around road hazards. On a very dark street your headlights will become nearly useless.
If your looking for a kit that will remove the cloudy, burnt plastic look from your headlights restoring them to like new condition then this is the kit for you. Unlike the quick fix kits you see on the market with just the clear sealant that only masks the burnt plastic which will ultimately flake and peel off. This kit will remove the cloudy haze look from the lights and will also add a layer of protection shielding them from the sun's harmful UV rays.
This kit will work on all plastic polycarbonate lenses without removing them from vehicle. Great for mobile detailers, car lots and even the do-it-yourself car lovers out there who maintain their own vehicles. Included are easy to follow instructions with pictures to guide you through the whole process from start to finish.
Included In The Kit:
M1 Polishing Cream - 12 oz.
T2 Polymer Sealant - 12 oz.
600 Grit Wet/Dry Sand Paper - 4 Squares
1000 Grit Wet/Dry Sand Paper - 4 Squares
1500 Grit Wet/Dry Sand Paper - 4 Squares
2000 Grit Wet/Dry Sand Paper - 4 Squares
Drill Mounted Velcro Backed Mandrel
Velcro Backed Twisted Wool Buff Pad
Velcro Backed Green Foam Finishing Buff Pad
2 - 16"x16" Microfiber Towels
Depending on the severity of the headlights this kit will restore 2-4 sets of headlights. We include plenty of polishing cream and sealant to restore approximately 10 sets of lights when used properly. Additional sheets of sand paper are available seperately in our Abrasives & Blades catagory on our site.
Kit Price:
$44.95
