nd Cleaned the Engine Top+Bottom aPolished Exhaust (Sorry 56K)
Old 09-28-2009 | 09:52 PM
Pitbull329's Avatar
lol,
anything I should be aware of before I go doing this to my car? Like avoid spraying degreaser on any certain part or something?
Old 09-28-2009 | 09:59 PM
98 WS6's Avatar
I hope not. I sprayed damn near everything. If you're doing the engine bay too, just watch the PCM, coil packs, dipsticks, fuses, stuff like that. I like to cover anything sensitive with aluminum foil to keep the water away. But for the underbody, SPRAY AWAY!
Old 09-28-2009 | 10:10 PM
Pitbull329's Avatar
LOL.
Ok, so spray away I will. Engine bay is very clean, except you know... the dust buildup after a week or two. Will rinse it down, and while Im there I will clean the tb the best I can.
Thanks!
Old 09-29-2009 | 10:51 AM
COKEBOTTLES's Avatar
looks awesome! i need to do that to mine.lol
Old 09-29-2009 | 12:17 PM
Chadlee2KZ's Avatar
looks good!!
Old 10-02-2009 | 11:57 PM
slayerized6's Avatar
i cleaned the rear section of my car today...holyyyy **** that was a lot of grease. wish i could of done the front too but my driveway was flooded and i was soaking wet. the gunk built up on the rear end and torque arm is stuck on there like cake.
Old 10-03-2009 | 10:39 AM
98 WS6's Avatar
LOL. I powerwashed the rear, but I don't think it did much like I did up front by hand. My driveway shined like a multicolor rainbow from the grease rolling down it
Old 10-03-2009 | 12:27 PM
Striker's Avatar
Huge improvement, I can relate. But I dont drive mine in any sort of foul weather. Rain, drizzle, snow etc. What I would do not is throw on some sort of rust inhibitor. I use this stuff made by a company called LPS comes in a teal/green can. They use it in the aviation industry and in a lot of steel mills and other small shops-
My 99
LPS-
Old 10-03-2009 | 02:37 PM
98 WS6's Avatar
Looks damn good man. Thanks for the suggestion I'll check that stuff out.
Old 10-05-2009 | 07:13 PM
Pitbull329's Avatar
Ok so I just finished doing this a while ago.
I was wondering how you got an easy view of the rack. Then I came in here and saw you had plenty of aftermarket parts lol. I only got to do the oil pans and under the engine block. Toook for ever with the little steel brush i had
I was using Simple Green, worked pretty good. Came out looking like a dalmation, but hey! I left it pretty damn clean. I cleaned the throttle body a bit. I want to inject MCCC into the intake to leave the internals very clean.
What was all that stuff stuck in your tranny cooler? My radiator was clean except for a paper towel stuck up in a corner.
Old 10-05-2009 | 10:05 PM
98 WS6's Avatar
^^ Sounds like you had a good time! I used MCCC about a month or so ago. Was extremely easy to get in there, I hooked it up to the vacuum line on the TB.
And I don't know, it was just gunk. It was leaking a bit a while ago so I think some stuff got caked in there.
Old 10-05-2009 | 10:35 PM
  #32
Pitbull329's Avatar
Oh, I did! I got the water hose and just had it cracked a bit while I scrubbed away all the grease buildup. My arms were black and face looked like I got splattered by a ballon filled with oil.
How much was the MCCC bottle? Ive looked around here, but nobody has it
Old 10-05-2009 | 10:59 PM
  #33
MEZA TA's Avatar
good attention to detail, looks good.
Old 10-06-2009 | 12:16 AM
  #34
98 WS6's Avatar
Uhhh 7 or 8 bucks if I remember correctly? Go to any local dodge dealerships. If there's a specific "dealership" that's for Parts & Service ONLY.. go there. That's where I found it. Apparently, ALL the warehouses are out of it. The only bit that's left is the stock at dealerships and parts centers.
Thanks Meza!
  #35
Marc3.4V6's Avatar
hmmm, I think I want to do that to my steering rack too.
Old 10-06-2009 | 12:40 AM
  #36
98 WS6's Avatar
Came out nice, right?
You guys should see my engine bay now. I bought some engine detailer (not degreaser) ...omg.. Everything looks BRAND NEW
Old 10-06-2009 | 12:59 AM
  #37
Pitbull329's Avatar
Post pics of the engine bay when you get a chance.
I've been thinking of using that engine detailer, but unsure if dirt will stick to it badly. Also... did you spray the whole engine bay (including the belts)? Or did you avoid the belts? Last thing I want is, for it to start squeaking badly.
I will give the dealerships another shot again, nobody had any when I checked a while back.
Old 10-24-2009 | 05:30 PM
  #38
DaRReLL's Avatar
What grit of Sandpaper did you use on the exhaust?
Did you use a spray bottle with water to keep it damp, is it really necessary to wetsand?
I usually go to Fort Knox and put it up on a lift for a couple of bucks per hour. I will be changing the oil in a couple of weeks and plan on cleaning up underneath at the same time.
Yours definately looks much better....
Old 10-24-2009 | 06:20 PM
  #39
ramairracer's Avatar
i guess im spoiled at the dealersip i work at we have a special wash bay with drive on lift with a high pressure thingy, that comes out boiling hot! so theyres no need for scrubbingg and it looks better than what you did,
but i give you props for all that hard elbow grease you put in
Old 10-24-2009 | 06:30 PM
  #40
98 WS6's Avatar
I used 400, then 600, then 1000, then 2000, then a buffer with a white pad and metal polish. You need to keep the area wet. the spray bottle with soap keeps it lubricated.
